5065E stuck in park
   / 5065E stuck in park #1
jbain
Prague, OK
JD 5065E and Kioti DK35
Hi, my 5065E gets stuck in park. Has anyone else had this problem?
   / 5065E stuck in park #2
Probably linkage getting out of adjustment. Is this a shuttle or power reverser?
   / 5065E stuck in park #3
It's my understanding that the park is a pin that goes into a hole to keep things from rotating. It sounds like it might be binding, are you parking on a hill?
Hi, I have an extended warranty on this tractor so called the local JD dealer to come out to see what the problem is. This tractor has the power reverser transmission. The problem was water down in where the shifter goes into the transmission. The water froze so the shifter would not move. The rubber boot had a hole in it that let the water in. I felt really stupid as this problem was so simple. The tech got all the water out and replaced the boot and all is well.
   / 5065E stuck in park #5
Ah yes: DAS BOOT!!
I've had to replace both of those. The "gear shifter" and the "range shifter" boot. So check the other side too if applicable.
Did water get into transmission/hydraulic oil?
Ah yes: DAS BOOT!!
No water in trans. Checked the range boot and it's good. I'm going to watch them from now on. Thanks,
John Deere Gator (A53317)
John Deere Gator...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2021 BMW R 1250 RT Motorcycle (A55853)
2021 BMW R 1250 RT...
2019 CATERPILLAR 299D2 XHP SKID STEER (A52707)
2019 CATERPILLAR...
2018 TowMaster T-12D 7 Ton T/A Flatbed Trailer (A55852)
2018 TowMaster...
UNUSED FUTURE HYD MINI THUMB CLIP (A57193)
UNUSED FUTURE HYD...
