5065E stuck in park
   / 5065E stuck in park #1
jbain
Prague, OK
JD 5065E and Kioti DK35
Hi, my 5065E gets stuck in park. Has anyone else had this problem?
   / 5065E stuck in park #2
Probably linkage getting out of adjustment. Is this a shuttle or power reverser?
   / 5065E stuck in park #3
It's my understanding that the park is a pin that goes into a hole to keep things from rotating. It sounds like it might be binding, are you parking on a hill?
Hi, I have an extended warranty on this tractor so called the local JD dealer to come out to see what the problem is. This tractor has the power reverser transmission. The problem was water down in where the shifter goes into the transmission. The water froze so the shifter would not move. The rubber boot had a hole in it that let the water in. I felt really stupid as this problem was so simple. The tech got all the water out and replaced the boot and all is well.
   / 5065E stuck in park #5
Ah yes: DAS BOOT!!
I've had to replace both of those. The "gear shifter" and the "range shifter" boot. So check the other side too if applicable.
Did water get into transmission/hydraulic oil?
Ah yes: DAS BOOT!!
No water in trans. Checked the range boot and it's good. I'm going to watch them from now on. Thanks,
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2012 MAC MFG 53' WALKING FLOOR REFUSE TRAILER (A53426)
2012 MAC MFG 53'...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
Pallet of Misc Fabrication Steel (A52384)
Pallet of Misc...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2025 K731G UNUSED Flower Bed (A53117)
2025 K731G UNUSED...
