5065e fuel tank metal filler neck
   / 5065e fuel tank metal filler neck #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
Does anyone know if the metal filler neck on the plastic fuel tank is threaded onto the plastic neck or just pushed down on rubber o-ring. There are metal tabs that fit in between vertical ribs molded into the plastic filler neck. Just wondering what to expect when attempting replacement . I have significant corrosion on mine
I successfully replaced the metal filler neck on my 5065e, to avoid transportation costs to and from dealer (even though parts covered by warranty). My filler neck and chain (connecting cap to neck ) were badly rusting. I am assuming defective anodized coating? Anyway, the metal neck has 4 tabs that fit in between these plastic vertical ribs molded into plastic tank neck. The metal filler neck is threaded into the plastic tank neck with a rubber O-ring seated on the top flange of plastic neck . Take a flat blade screwdriver and bend tabs up 90 degrees to free interference fit, using needle nosed pliars. The new metal filler neck comes with 4 tabs ( spaced 90 degrees apart ) already bent 90 degrees out so you can screw the metal neck into the plastic neck. When you feel resistance from the O-ring seating, turn it a few more ribs to compress it. You obviously have to center the metal tabs between the plastic vertical ribs. Then just bend them down between plastic ribs to create an interference fit . When you remove cap, the counterclockwise rotation is resisted by the tab engagement. My dealer had a customer that was removing the metal filler neck every time they removed fuel cap because the tabs were not bent down . So if you are having corrosion of the metal filler neck, the repair is easy. I did use a pipe wrench to break gasket seal because the installer put silicone over rubber O-ring and that created some resistance to removal . The parts diagram did not identify silicone so I just used O-ring. Works fine.
   / 5065e fuel tank metal filler neck #3
Thanks for the update. It will help
future searches
   / 5065e fuel tank metal filler neck #4
do you happen to have a part number?
Thanks: Bob
L80418 called insert. Also a rubber O-ring underneath, L112337. Insert threads into plastic tank neck compressing o-ring. Metal tabs bend down into slots to mechanically prevent rotation.
   / 5065e fuel tank metal filler neck #6
Thanks. Mine is a JCB, but they only want to sell the entire tank for $900. So, I am hoping a John deer will fit.
(2) UNUSED Metal Garden Arbor Trellis (A53117)
(2) UNUSED Metal...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
Light Tower (A52377)
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
