5065e fuel Seder gasket leaking
   / 5065e fuel Seder gasket leaking #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
Try to keep tank full to minimize condensation in tank. After 1 year and 100 hours my sending untitled flange gasket started leaking fuel down side if tank. Obviously does not leak when fuel below flange. Replaced sender and gasket. Held for 2 weeks and started leaking, slow minor leakage. Removed and dressed flange and gasket with Permatex #2 sealant designed for oil, gas, oil pans- solvent based not silicone. Held for 2 weeks and started leaking. I am snugging up all 5 Phillips screws against the metal seal ring good and re snugging a few days later. Don't know torque spec on screws and afraid to strip threaded inserts formed in tank flange that received screws. It is under warranty but I can't transport tractor and it is not cheap to haul 80 miles round trip twice. Any advice ? Just keep snugging them up?
   / 5065e fuel Seder gasket leaking #2
Maybe check tank supports as well? Maybe a vibe issue is taking place and that area is carrying load.
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
Barth Foot Operated Shear (A51695)
Barth Foot...
Panel Cart (A51695)
Panel Cart (A51695)
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
