5045D John deere rock arm don't lift up...
   / 5045D John deere rock arm don't lift up... #1
gajen
John Deere 5045D
hi Sir i have 5045D John deere Tractor .. The problem is when i start the machine rock arm lift up slowly @ 500 or 600 RPM after one minute or try to lift up 2nd time it never rise up so i need to increase RPM to 1500 or upper after one hour work it hesitate to lift up .. i changed hydraulic pump but no improvement .. some times it don't lift down so i just increase the RPM to lift down .. give me a solution sir
Thanks in Advance
   / 5045D John deere rock arm don't lift up... #2
i have no idea what it could be ..hope you get it figured out
   / 5045D John deere rock arm don't lift up... #3
Been there. All it takes is a blown O ring inside the case that lets pressure blow by. A trip to your dealers shop is the fastest and best fix.
   / 5045D John deere rock arm don't lift up... #4
Welcome to TBN
No or slow raising 3 pt sounds as if rockshaft piston is leaking
Need to adjust hydraulic relief pressure valve ? .. @ Tx Jim ya piston seal also little damage .. passed 2100 Hours with heavy PTO works ..
2020 John Deere R4023 Sprayer (A53342)
2020 John Deere...
UNUSED INDUSTRIAS AMERICA F08 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
1996 MEC 2548 ELECTRIC MANLIFT (A51246)
1996 MEC 2548...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
