5045D John deere rock arm don't lift up...
   / 5045D John deere rock arm don't lift up... #1
gajen
John Deere 5045D
hi Sir i have 5045D John deere Tractor .. The problem is when i start the machine rock arm lift up slowly @ 500 or 600 RPM after one minute or try to lift up 2nd time it never rise up so i need to increase RPM to 1500 or upper after one hour work it hesitate to lift up .. i changed hydraulic pump but no improvement .. some times it don't lift down so i just increase the RPM to lift down .. give me a solution sir
Thanks in Advance
   / 5045D John deere rock arm don't lift up... #2
i have no idea what it could be ..hope you get it figured out
   / 5045D John deere rock arm don't lift up... #3
Been there. All it takes is a blown O ring inside the case that lets pressure blow by. A trip to your dealers shop is the fastest and best fix.
   / 5045D John deere rock arm don't lift up... #4
Welcome to TBN
No or slow raising 3 pt sounds as if rockshaft piston is leaking
Need to adjust hydraulic relief pressure valve ? .. @ Tx Jim ya piston seal also little damage .. passed 2100 Hours with heavy PTO works ..
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
LANESHARK LS3 LOT IDENTIFIER 148 (A53084)
LANESHARK LS3 LOT...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
