5045
   / 5045 #71
I believe a loader may throw off the balance of a good plowing tractor. Despite what some people think, plowing is important, and doing it right is essential. If plowing wasn't that important, then it wouldn't be such a fudamental part of agriculture. Anyways, the tractors I am looking at, the John Deere 5045e,or 5055e I believe the Loader is permanetly mounted to the Tractor. Taking it off, and on isn't all that easy I think. Here is a link to plowing...Sherwood Forest Ploughing Match - YouTube
   / 5045 #72
I think you are misinformed about the loader, the 553 loader for the 5045E is removable. I am not a fan of loaders on my tractors but I do feel if you only have one tractor you need it to have a loader attachment. There are alot of guys here trying to give you good solid advice, hope you will consider some of the help you have been given.
Here is the page for the loader made for the tractor you are considering. Scroll down the page below the bucket in the picture and select features, then look at parking the loader.
JohnDeere 553 Loader Loading and Digging Attachment JohnDeere.com
   / 5045 #73
I believe the 5045D model has a permanent loader attached, although they are not completely permanent, just not practical to take on, and off. I know how much easier a loader would make things. It would come in handy, I don't question that. I also need to buy, a good plow, a good rotary cutter, a good rotary tiller, a box blade, a ripper, a garden bedder, a wheat thresher machine (9600.00), a potato digger, a manure spreader, a seeder, a fertilzer spreader possibly. If I go with the 5055e with loader, that is $28,500.00 plus tax.. JD Rotary Tiller was $3100.00, Frontier 2 Bottom plow was $1200.00, wheat threshing machine I priced was $9600.00. Tell me some daily functional uses of a loader on a tractor, or primary uses for a loader, that may help me be convinced I should invest the extra money in one if I really need one. I am not one to waste money, especially no $28,500.00 I appreciate all of your all's suggestions..
   / 5045 #74
i dont know if you have cattle or not but the loader can be used to move an feed hay.an it can also be used to move dirt,an level up.an you can also use it to unload stuff.
   / 5045 #75
How many acres of wheat are you going to plant?
   / 5045 #76
I am not sure, it will be primarily for personal consumtion. 1-4 acres..
   / 5045 #77
the 5045D uses the aformentioned 553 loader and is simple to remove/replace.
If you are not convinced you need the loader then don't buy it as you can add it later if you change your mind. I don't have a loader on my 4520 either.
If you look at my signature line I think you can see that I am well aware of what implements cost.
Loaders are handy for moving stuff, and there is always something that needs moving from my experience. I used to do it the hard way but a loader does save time which is valuable and energy which I have less of as I grow older.
   / 5045 #78
I am looking for a good tillage work tractor. One to plow with, till with, cultivate, etc.. A good ground engaging versatile tractor. I don't plan on taking if fourwheelin..lol I have been looking for a good pull tractor. It seems a well ballasted 2wd is the way to go in that direction. As during plow days, the antique 2wd models seem to be the tractors of choice, and preference. I can not use experience with either 2wd, or 4wd to use that in my decision making. Given my future intended purchases including the land itself, I looking at Implements like:
AG List: Utility List:
Rotary Cutter Box Blade
Good plow Post Hole Digger
Disk
Good Rotary Tiller
Garden Bedder
Ripper
Subsoiler
Manure Spreader
Seeder
Fertilizer Spreader
Other considerations:
Method to harvest Wheat, possibly mini combine, or small antique harvester
made by Allis Chalmers if available.
Other Tools:
New Chainsaw
Generator
6000lb Come A long
Metal Fuel(Diesel) Can
Metal Fuel(Diesel) Tank
Farm Jack
Livestock List:
Dair Goats
Chickens
Also note: I may invest in a small compact tractor with loader in the future, for loader applications, so just thought I would mention that..
   / 5045 #79
That is just a general idea of things I plan on acquiring in the near future. It would be nice to take out a loan for all of those things, and just pay off the loan for those things..
   / 5045 #80
Shannon,
Looking at your list I didn't see anything that is out of the ordinary needs. You can do those jobs with most tractors sized from 40 to 60 hp. I would think that a 4520 such as I have would handle those tasks well. I have owned the heavier built 2wd tractors and the compact 4x4 tractors and both will handle the majority of the work you can do with your implement list. An ehydro tractor will handle tillage on a small property without problems and is easy to use for some of the other tasks. Not saying you need an ehydro tractor but pointing out that you don't have to have a gear tractor, either will work.
Just consider that hp and weight determine how much you can pull and how fast you can pull it. If you plan on using the tractor alot I would recommend you get the higher hp model so that you can get more done in a shorter period of time.
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
1989 W-W Stock Trailer (A50514)
1989 W-W Stock...
2019 Caterpillar DP35N Forklift (A51691)
2019 Caterpillar...
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
