5045 E blowing key switch fuse
/ 5045 E blowing key switch fuse #1
rnccen
San Antonio, TX
Massey 135
Jd 5045 E keeps blowing 30A key switch fuse, I saw some other posts about disconnecting temp sensor aka cold advance switch in the thermostat housing but this tractor doesn't have a cold advance switch there.
Anyone know if they put it somewhere else?
Tractor is sitting in a field in Texas, just trying to get it started and back to the barn where tools are.
Thank you in advance
/ 5045 E blowing key switch fuse #2
I'll bet your tractor has a cold start relay somewhere. What is your tractors serial range? Example 143xxx or 129xxx
/ 5045 E blowing key switch fuse #3
You must have a common rail system and it probably doesn't use a cold start circuit. They have other means of monitoring and dealing with temperature changes. If you're blowing fuses the problem could be most anywhere.
/ 5045 E blowing key switch fuse #4
Put a lightbulb in the place of the fuse that blows. The light will act as a fuse until you locate the grounded wire in the circuit. Then start moving wires around and unplugging or disconnecting things until you hopefully find the culprit (light goes out).
Has been a fuse-saver for me several times.
Dealer confirmed no cold start for this version of the 5045e. Ill try the light bulb, local dealer is 6 weeks behind in service. I can't wait for them.
If anyone else has any hints tips tricks, I'm open to suggestions.
/ 5045 E blowing key switch fuse #6
There really are no tricks. It's blowing just the one fuse? If you can't find any physical damage to wiring,(as in rodent nest residue) you need to first determine what all circuits that fuse supplies. Then you start following the easiest ones first. Look for wire issues anywhere, then start unplugging various electrical components until you locate a short to ground type of situation. It helps to have book with wiring diagrams and component locations.
/ 5045 E blowing key switch fuse #7
If you employ the light bulb trick just make sure you locate the bad wiring quick or the unit might start afire.
2013 LAY FLAT REEL TRAILER (A65643)
2013 LAY FLAT REEL...
60in. Work Bench (A65640)
60in. Work Bench...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
7' Barnwood Bar Table (A66408)
7' Barnwood Bar...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
Land Pride RB3584 3-Pt Blade (A66408)
Land Pride RB3584...
