5035 remote lines routing
/ 5035 remote lines routing #1
930ck
southcentral kansas
allis d 17/ case 930, 1370/ kubota L5740
The 5035 that dealer has still has the rear remote lever by the seat but noticed the new ones have the lever on the fender, was wondering how they ran the lines to the back and how they were protected. The fender location looked more convenient as long as the lines are not exposed.
/ 5035 remote lines routing #2
I am not sure that the remote valve located next to the seat is an older option than having the remote levers up on the fender next to the FEL control. From what I have seen, I think the dual fender levers are the 'remote cable operated' type [ like the FEL lever ] and the valve for that setup is located down on top of the right rear axle area... If you look around on the Mahindra site you will see pictures of the '35 series rear with the valve and line setup like that. I'd do it, but since they upgraded the site... my out in the boonies dial up modem speed really sucks... :)
/ 5035 remote lines routing #3
My dealer installed these triple remotes on my 2008 Mahindra 5525 when I b bought the tractor.
Was just curious if the fender mounted controls are protected from mud and debris, also just looking at the pictures it looks like the hydraulic lines seem more out in the open. Don't know anyone with a 5035 but have done a search on this forum and have not found a comment on the controls so there may not be a problem with the routing.
