5035 Owners-check this
   / 5035 Owners-check this #1
Bascom
Savannah, Georgia
2010 Mahindra 5035
Had 4 bolts on the front end of my 2010 5035 come loose at 80 hours on the meter.
My dealer consulted the factory rep and they replaced all 4 (under warranty) due to the original bolt shoulders being too short. Dealer support was above and beyond in getting the problem solved!:thumbsup: Thanks Levi!
The red arrow in the first pic shows the new, brass colored bolt as seen from the right side, aft of the front axle. The same bolt on the left side needs to be checked/replaced as well.
The second pic shows both replacement bolts as seen from the front of the tractor.
I'm not sure if the 2011 models and / or other -35 series tractors would have this issue or not.
Recommend checking them.
The .psd files are not opening for a couple folks. Will post the same pix later today/tomorrow in .jpg format.
PM me if you want any further details.
  • Front1_5035_edited-1.psd
  • Front_5035_edited-1.psd
Oops! Didn't realize the .psd pix would be a pain for some to open. Won't do that again!
The first pic is a view from the right side looking at the backside of the front axle / driveshaft. The bolt that was loose is in the upper right portion. The same bolt on the left side was loose.
The second pic is a closeup of the first.
Third pic is looking at the center of the front axle from the front. Only one bolt was loose, the dealer replaced both as seen on both ends of the "yoke".
FYI, there were lock washers on the original bolts, but they backed out due to the bolt shoulder being too short.
Hope this helps!
   / 5035 Owners-check this #3
Thanks for posting. I'm gonna check mine tomorrow.
Dan.
   / 5035 Owners-check this #4
I just noticed this post and checked my bolts this morning. They had 30mm hex heads and were all tight. Thanks for the heads up.... and keep them coming..!!!!!!!!!! :)
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
KSI Conveyor (A52748)
2017 FORD TRANSIT T150 CARGO VAN (A52577)
2017 FORD TRANSIT...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
