5035 front end squealing at way faster rate than tires....
   / 5035 front end squealing at way faster rate than tires.... #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Been making new roads out back in the woods... My 5035 @ 451 hours started making squealing noises once and awhile while I was out pushing over trees, rip'n and tear'n, and generally mistreating my tractor.... Did not see any fluids leaking or wheel wobbling... took it back to the barn thinking all kinds of nasty thoughts. Checked the fluids, and they were good. Turned out to be the idiot low life operator drove over something [ actually many somethings ] and bent the front drive shaft shield so it touched the shaft once and awhile.... Restored it to it's proper place with a wooden handle.... Now thinking happy thoughts.... :)
   / 5035 front end squealing at way faster rate than tires.... #2
"Ive had many worries in my life, most of which never happened." Mark Twain
Glad it was an easy fix!!
   / 5035 front end squealing at way faster rate than tires.... #4
My 4110 did that, it was low on gear oil in the front axle due to a leak in the axle cap on one side.
That was my first thought.... I have a front end that might have a tire/axle assembly falling off.... I have something coming loose within the front end and getting end play in the axle shaft/some gear.. My tractor is falling apart and I am going to have to tear into it/or send it in for a LONG TIME... every squeak squeak squeak as the tire started to rotate created chills up my spine [ I mean, the spine of the idiot operator... ]... But, LIFE IS GOOD....!!!!!
   / 5035 front end squealing at way faster rate than tires.... #6
I've had the same thing happen multiple times. Tightened the crap out of the bolts after straightening the shield. No issues thus far
   / 5035 front end squealing at way faster rate than tires.... #7
You might want to think about sacking the operator! :D
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
2012 Ford F-350 4WD Pickup Truck (A50860)
2012 Ford F-350...
Tubing A500 Grade C 6in. SQ x 1/4in. x 28ft. (A50860)
Tubing A500 Grade...
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A50860)
2015 Top Hat T/A...
2016 Ford F-550 Crew Cab Mason Dump Truck (A48081)
2016 Ford F-550...
