5030 L
/ 5030 L #1
laff 3
El Cajon Ca.
Kabota 5030L
Hi I have a 5030L , yesterday when I started it up the battery light would not turn off. I check voltage at the battery,12 volts, I checked output of alternator 12 volts. I assume this means the battery and alternator our operating correctly? Any ideas what my problem might be? Thanks Tom
/ 5030 L #2
I thought it should put out more... like ideally between 13.8 and 14.2 volts (at least for a car),
PS. can you add Electrical problem or alternator problem to the title??? might get better response. :2cents:
/ 5030 L #3
Tom, your alternator isn't working. Right after startup it should be recharging the battery at somewhere around 14 volts. This would be reflected at the alternator output and at the positive post of the battery.
If you have a manual look in the troubleshoot area. Might get lucky and get guidance. There are several things that could be wrong. I usually apply the K.I.S.S. principle (keep it simple stupid). Not having looked at your tractor, I assume the regulator is built into the alternator? If so there should be a 18 gauge or possibly 16 gauge wire that would be the trickle wire. It should have 12V when the key is turned on. Dead when the key is off. If you can't find a wire doing that and if the regulator is built into the alternator, there is nothing telling the alternator to charge. That trickle wire voltage is what activates the regulator.
Until you give us more information I don't know what to add. Take a pic of your alternator showing the wire hookups. That will tell us what type you have.
I don't know if you can change your thread title?? If you can then add "alternator not charging" or something like that. Only people going to open this thread is someone that is interested in a 5030L.
/ 5030 L #4
You beat me to it while I was rambling on..... :)
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
HARDEE 4R SPRAYER (A63291)
HARDEE 4R SPRAYER...
Fair Oaks 10'  Multigrader Blade (A64047)
Fair Oaks 10'...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
208320 (A58375)
208320 (A58375)
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
