5030 HSTC Fifty hour service
   / 5030 HSTC Fifty hour service #1
fuelburner
Virginia
5030 HSTC
Spoke to the parts gal at the Kubota dealership and wanted her to order all the filters etc. needed for 50 hour service. She had everything in stock and while we were going over the items to be purchased she had only included 1 gallon of super UDT. When I questioned here about this she explained that the service department routinely just replaces the hydraulic filters and then tops off the fluid level at the 50 hour service and performs a complete hydraulic oil change at 400 hours. What do you think about this practice.
   / 5030 HSTC Fifty hour service #2
If the fluid looks good..smells A-OK..etc...most probably not a bad practice. If it looked and smelled like you had used it HARD..and I do mean HARD for the first 50....let it drain out.
The hydraulic oil on the dip stick is clear and dose not smell burnt. I recall on my TC 40 D that the recommended change interval was at 300 hours.
   / 5030 HSTC Fifty hour service #4
I had the same advice from the parts man at my dealer. At first I was only going to change the filters, but on second thought Kubota recommended changing the hydraulic oil. It's only a couple of hundred dollars to protect a large investment. I went back and bought 15 gallons of Super UDT and changed everything at 50 hours. I won't have to change the oil again until 400 hours and I will have followed the manufacturers instructions if the need for warranty work ever arises.
It's your decision, you pay your money and take your chances.
Leroy
   / 5030 HSTC Fifty hour service #5
I suppose it's OK if you have confidence in the screen holding onto the small metal shavings, etc. for 400 hours.
My B7510HST is due for its 50-hour maintenance now. Today I bought the SUDT (5 gal) and the three filters (one for engine oil, two for the hydro system) at my local Kubota dealer in Chico, CA. Cost about $130, including $90 for the SUDT. This is a little pricy for SUDT, judging by what I read in these forums.
Some folks swear by the $40 stuff you can get at TSC, Sam's, Costco, Napa or WalMart that's supposed to work OK in place of SUDT. But $50 extra for the real stuff to protect a $12K investment is a no-brainer. At the rate I'm using my tractor, it'll take 3-4 years to reach the 300-hour service point where the next hydrofluid change is scheduled. That's about $25-30/year for SUDT--not a problem.
   / 5030 HSTC Fifty hour service #6
Filter only here also. Dealer said the same.
Thanks to all for the feedback, just finished the 50 hour service , bought 15 gallons super UDT and even have a couple gallons left over. cost 280.00 for everything. Snowing outside as I speak might get to push some snow tomorrow.
   / 5030 HSTC Fifty hour service #8
fuelburner:
Every, and I mean every Kubota I have owned (7), all stated in the manual to do a complete fluid change including front differential case at 50 hours. My only substitution is the front case gets 85-140 Shell Spirax GL4-5 hypoid oil. I took a tip from another long time poster here (Rat) and this time I ordered 15 gallons of Chevron THD synthetic fluid. It's priced right in between UDT and SUDT and coincidentally has a nice orange color that's easy to see on the dip stick.
In my case, 15 gallons of hydraulic oil and a few gallons of 85-140 is chump change compared to a $46,000.00 tractor and a possible denial of warranty service (if it ever arises though I have never had any warranty issues with Kubota) because of not timely following the maintenance schedule.
   / 5030 HSTC Fifty hour service #9
Here's a compromise - for our L3830, the dealer advised changing the SUDT at 200 hrs. I was a little leery, because it was at odds with the manual, but I went with their advice.
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2013 John Deere 824K (A52748)
2013 John Deere...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
2007 MACK CV713 WINCH TRUCK (A52472)
2007 MACK CV713...
