5025 HST questions now that I've driven it a bit
   / 5025 HST questions now that I've driven it a bit #1
Ram4x4
Nickleville, Pa
Mahindra 5035HST
Ok, so I've had a chance to work with the new 5035 HST and I am wondering...
When I press down on the pedal to get moving there is 4-5 second delay before it starts moving. Is this normal? Especially noticeable when using the FEL and I scoop, back up, then switch to the forward pedal to get moving there is that long delay. It starts slow and after a few more seconds you can kind of feel it "grab" as it starts to move. If this normal then OK, but after a lot of backing up, going forward it's kind of annoying as I'm sitting there with a "ok, let's go" feeling after hitting the pedals to get moving. I'm running her at around 2000 RPM when using the FEL which seems a decent RPM to work at. Mowing I run her up to the 540 mark on the tach which around 2200 RPM.
Also, the brakes seem useless. After rolling, letting off the pedal and hit the brakes there seems to be no braking effect and the tranny starts whining hard like the brakes are fighting it. It's like letting off the pedal doesn't want to "disengage" the HST. Especially bad when going down a slight grade as the brakes will not stop the tractor at all. Might as well not have any brakes at all.
I hope this isn't normal and it's just a matter of some kind of adjustment or something.
   / 5025 HST questions now that I've driven it a bit #2
That does not sound normal for any HST tractor I have ever used.. Neither condition. Some are more responsive than others when going from fwd to rev. and on the HST+ Kubota the response can be adjusted. But on my old L3400hst kubota it was adjusted to extremely responsive, on my Kioti not quite as responsive, but still nothing like the 4 to 5 second thing.. Maybe 1/2 second on the Kioti, and the Kubota was 0 seconds.. The pedal should center when you let off, and no way the brakes should be "fighting the transmission" and you are hearing the whine increase, so I am guessing that is exactly what is happening... Take it to the dealer.
James K0UA
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2008 Ford Escape XLS SUV (A59231)
2008 Ford Escape...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
