5005 DI Power Steering Fluid
/ 5005 DI Power Steering Fluid #1
awill99
Bronze Member
15 acres Celeste
Mahindra 6500 4WD with Skid Steer FEL.Mahindra 3616 HST with Skidsteer, Vermeer RT200 Trencher
On the power steering reservoir it says use automatic transmission fluid Type A or F and gives Dexron II as example of type F. My 2005 DI Operators manual says Dexron III. Whats proper fluid?
/ 5005 DI Power Steering Fluid #2
I would go with the Dexron III. It's the most current spec fluid and replaced Dexron II.
/ 5005 DI Power Steering Fluid #3
I use Dexron III in my 5005. I learned real quick not to get all uptight about what was in the manual vs. what I put in everything else. I think when Mahindra got the tooling rights to the old Internationals, they also copied the fluid reccomendations.
2025 LandHonor RGB-11-72W 72in Hydraulic Dual Cylinder Rock Grapple Bucket Skid Steer Attachment (A64553)
2025 LandHonor...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
Ford 550 Backhoe (A65579)
Ford 550 Backhoe...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2019 ASV RT-25...
500 GAL POLY FLAT BOTTOM TANK (A64277)
500 GAL POLY FLAT...
