Snow 5000 Series Snow Plow / Dozer
   / 5000 Series Snow Plow / Dozer #1
WackyWRZ
Omaha, NE
Hey, I have a Cub Cadet 5234D that I am looking into putting a snow blade on. I have seen the Deere ones all over ebay with the hyd. control for $300-$500, and wondered if anyone here has any experience on if these will adapt to the CC unit. I have a welder and plenty of steel at my disposal, but dont want to put tons of time into fabbing a mount bracket if theres a better option. If not, does anyone have any suggestions on what to put on it. It doesn't necessarily need hydraulic on it, but I figure that if I have the option on the tractor I might as well.
Thanks!
   / 5000 Series Snow Plow / Dozer #2
Does your have FEL?..if so would you fit snow blade to bucket or loader arm,or fasten to tractor main frame.
Welcome to TBN. :)
   / 5000 Series Snow Plow / Dozer #3
Hello -
Man that's loaded question. I also have a 5234 with a Cub front hitch/blade. You might be able to duplicate the standard setup, but if I could get a NOS front hitch and blade I'd do it. I know around where I am I can get a new blade for around 500, but the hitch and PTO setup is a bit harder to find. I plow snow with it and it is a fantastic setup.
Welcome to TBN. :)
Thanks for the welcome!! I have found a lot of useful information on here! I am assuming FEL is front end loader, and if thats the case, no. All that I have is the tractor. I would just want to mount the blade to the frame.
Scoutcub, what would I be hooking up to the PTO? I just figured I would mount the plow to the bracket under the front frame, and hook the hyd. lines up to the connections. I would assume NOS is new old stock, and i'd be best to call up a cubby dealer here and ask them?
I've even considered just buying a regular garden tractor plow (like you'd find on a sears) and putting that on there, but don't know how that would work compared to a beefier one.
   / 5000 Series Snow Plow / Dozer #5
Just get a used ATV blade and bolt the mount to your frame. You can do 5-6' with that tractor but probably no more. I have one (6') I mount to my bucket and it works great. Been using it for years with no problem. It's on a 20HP diesel. I think I have around $150 total in the blade and the mods I thought I needed. In retrospect I don't think I really needed to do anything but bolt the ATV mount to the bottom of my bucket and rig something to control vertical movement of the ATV mount. A cheap chain would probably have worked just fine..No way would I spend a bunch of money on over priced snow blades that sit idle for most of the year.
   / 5000 Series Snow Plow / Dozer #6
Oops sorry the PTO would be for a blower. I might have a front hitch as well, all you would need is the cylinders if you wanted power angle, it's what I have and it work great. You can ask around the Cub dealers, but these parts are few and far between. Send me a PM and I'll let ya know.....
   / 5000 Series Snow Plow / Dozer #8
Great call....$1000 for a blower/hitch and blade is an awesome price.
   / 5000 Series Snow Plow / Dozer #9
iam looking for a blade for a 5252 cub cadet .
   / 5000 Series Snow Plow / Dozer #10
I have one for sale.
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2016 Ford Fusion Hybrid Sedan (A55758)
2016 Ford Fusion...
2014 Electric Cart (A53424)
2014 Electric Cart...
Daewoo GC255 (A53314)
TMA (A49461)
TMA (A49461)
