Oil & Fuel 50 hrs is coming up fast. Flush???
   / 50 hrs is coming up fast. Flush??? #51
I'm finding that I will put 3-4 hours on it then go a week without using it. She certainly gets up to temp in that time. In about 2 weeks time I will be done my spring work and she will sit for a few months. Then I will have a bunch of work in the fall for it. I don't mind using synthetics on the engine. It's cheap.
The hydro, I may just use Donax Td. It's easy to get around here and 1/3rd the cost of synthetic. Correct me of I am wrong but the hydro oil wouldn't see the temps that the engine would. Is that a good assumption?
I don't know how hot the hyd. oil gets if your not doing ground engaged work? I assume your tractor has a hyd. cooler so I think you'll never over heat it anyways. I put shell spirax s4 txm(Donax replacement) in for my 50hr service but I find its a bit noisier from the gears than I remember the factory fill being... HST seems the same but next change I think I will try something else. My dealer uses valvoline tractor fluid so I might go with it next time.
UNUSED FUTURE FT72 72" HYD MULCHER (A58376)
UNUSED FUTURE FT72...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
DRAGON 500 BBL ACID TANK (A58216)
DRAGON 500 BBL...
Dump Truck Snow Plow Mount (A55272)
Dump Truck Snow...
(2) 35X12.50R17LT TIRES ONLY (A58376)
(2) 35X12.50R17LT...
40' CONTAINER (A58376)
