50+ Hrs in the first month...
   / 50+ Hrs in the first month... #1
vwgtiman
Hegins, PA
Kubota B2320
Well, we have the B2320 for a little over a month now and its already time for the 50 Hr service... Am I seeing some of the posts here correctly and people have tractors out there that are years old and haven't hit 50 hrs yet??? :confused:
   / 50+ Hrs in the first month... #2
So put on hours just like you! And some add them slower. Many put on hours faster when they just get them after the initial work is done.
   / 50+ Hrs in the first month... #3
That's alot of hours in a month... especially if your hour meter is like mine. I spend three hours working and the hour meter moves about .6 hours. When I trade up, someone will get a tractor with nice low hours!
   / 50+ Hrs in the first month... #4
My old tractor was "hours at pto rpm." So if I modulated the throttle (which I usually did) then it only recorded a fraction of the actual run time. My dad's old Massey is the same way. My new tractor records actual time running so it racks up hours a lot faster.
In 7 months of owning my old tractor it recorded 22 hours. In one month on my new tractor it recorded 11. Same amount of weekly usage on both.
   / 50+ Hrs in the first month... #5
   / 50+ Hrs in the first month... #6
I have 67 on mine. got it on Good Friday in April.
Probably go a little slower now, I had a pretty good sized project to work on every evening after work.
James K0UA
   / 50+ Hrs in the first month... #7
out of all my tactors: JD 3120, Bx 22, KX 91, Bx 25, Bx 1830, GT-235, X-575, L-2800 I put the most hours on my BX-22, (450) At the time the work was good and the BX-22 was the perfect tractor for the task at hand. I was hoping to do more with the KX-91 until the economy flopped. who knows when our tax and spend Government will halt their attempt to bankrupt America.
   / 50+ Hrs in the first month... #8
The amount of hours you put on is relative to the amount of work you do and in what time period you do it. It's pretty simple:
A lot of work in a short amount of time = a lot of hours adding up fast
Little work over a long period of time = few hours adding up slowly
Pretty simple. ;)
That aside, when we first got the BX, I put a lot of hours on it very quickly. Now that most of the projects that I was able to do are done, the hours are adding up a lot slower...
2015 Chevrolet Impala Sedan (A46684)
2015 Chevrolet...
2016 Lincoln MKZ Sedan (A46684)
2016 Lincoln MKZ...
2013 Chevrolet Cruze LS Sedan (A46684)
2013 Chevrolet...
Truck Hitch (A46684)
Ferguson 2-Bottom Plow (A49251)
Ferguson 2-Bottom...
TPM 40' Container (A49251)
TPM 40' Container...
