pkav32
I just went to my JD dealer to get the filter pak for my 2520. I was told that I did not have to change all the filters and fluids. In fact I was told to just change my oil. I believe that contradicts the manual. Any thoughts?
There have been a number of other posts about the 50 hour service for the 2520 here on TBN. One fellow stated that his dealer would do the service for $700 and change!!
Seem to recall that Orlo felt the owner's manual required "ALL" the fluids (including the anti-freeze) needed to be changed at 50 hours.
I thought that was a "bit-over-the-top" so, I asked one of the neighbors to look it up in his manual. The manual states that oil, filter, hyd fluid, hyd filter and sump filter cleaned at 50 hours. Nothing about the coolant.
The filter and hyd fluid (4 gallons) adds about $85 to the cost if you do it yourself. Not that much, but is it really all that necessary after only 50 hours?!?
If it were my machine; I'd change the engine oil and filter and the hyd filter. Change the hyd fluid at 200 hrs.
AKfish
