50 hr service on my 2520
   / 50 hr service on my 2520 #1
Mercmaniac
Bronze Member
Montrose, PA
John Deere 2520 & John Deere 445
At 46 hrs I decided to get this done. I researched a lot of previous posts for the 50 hr service on this tractor before I tackled it and the info given here was of great help. All went smooth until I noticed trans fluid leaking at my suction screen cover. I snugged the cover bolts a little more but still had the leak. I ended up going to a dealer and purchasing a new o-ring for the cover. I drained off 3 gallons into a clean container pulled the cover and changed the o-ring. So far nothing is leaking. At $1.84 for the new o-ring, I will include that in my items to get for the next transmission service.
   / 50 hr service on my 2520 #2
Glad it all went well merc.:thumbsup:
Not too many things on JD tractors can be fixed for $1.84.:)
Greg
   / 50 hr service on my 2520 #3
Greg
Or on any tractor. :confused2:
I hear ya Greg. $1.84....whew. I won't be so lucky with my 445. I also discovered a trans leak on that. It is leaking near a shaft on the side of the trans that the reverse pedal linkage is connected to. Some type of seal around the shaft I am assuming. The problem is getting to it.
My v-bars are on there way!!!
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
VOLVO QUICK COUPLER MAST W/ 72" FORKS (A52705)
VOLVO QUICK...
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
Genie GTH-644 (A50490)
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
