50 hr oil change
   / 50 hr oil change #41
The 50hr service is totally doable on your own. Just don't forget to do the other things on the list after changing fluids and filters. It is a great time to get under the tractor with wrenches to check tightness and lube all those hard to reach zerks. Invest in a maintenance manual if you don't already have one. I cannot recall if Kioti has updated the CK manual (the old one was not great) but I can vouch for the new DK manual as a model of how these things should be written and illustrated. They cost about what you'd pay the dealer for an hour of a mechanics time so are good values.
To me, doing it myself is not about cost. It's about knowing that every plug was removed & replaced with the right tool; that every drain location was allowed plenty of time; that the magnets were cleaned completely; that every thread, both male & female, was wiped clean and inspected; that the filter can was thoroughly cleaned; that every barely visible zerk was wiped, greased, wiped; that the air cleaner cover and compartment were cleaned; and that everything was put back properly. That leaves just one thing: what to do with an overfilled 5-gal can of used fluid (besides storing it in an old shed).:) Dean
   / 50 hr oil change #42
Our township is having a collection this Saturday!!! I am geeked to get all the jugs of waste oil out of the shop.
Guy in the village supposedly has a burner, but I haven't connected with him yet. So, it's off to the re-cycle day. Only wish they'd do it more often.
   / 50 hr oil change
Up here there a store that sells oil must take the used oil. Good deal for me..as long as the container stays sealed on the trip out my road.
   / 50 hr oil change #44
I had posted earlier I did not have that much trouble getting my filter off, now remember :rolleyes: I used a pair of very large channel lock pliers. :)
Yep, the big channel-locks make stubborn filters a piece of cake (my CK20S HST filters were TIGHT) ..... I don't even know where my 'filter wrench' is anymore 'cause I always use the C-locks on all my filters :)
   / 50 hr oil change #45
something that worked well for me on a tough filter to remove, was to cut a strip of sand paper to fit around the filter . Make it twice as wide as the filter strap wrench . fold it in half long ways , grit facing out and insert between filter and wrench . Good luck!
   / 50 hr oil change #46
.....That leaves just one thing: what to do with an overfilled 5-gal can of used fluid (besides storing it in an old shed).:) Dean
Find a local bull dozing, excavating, heavy equipment operator...they'll probably be glad to give you a few empty 5gal drums...they can use the used stuff to lubricate the giant earth movers or some of the other really heavy equipment that has large chain drives.
   / 50 hr oil change #47
Just a note I tried 3 type of filter remover tools, none worked, what did was a welders locking vise grips the ones with a chaine built into them, worked like a charm.:D
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2013 Chrysler Town and Country (A56859)
2013 Chrysler Town...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
Caterpillar Midi Excavator (A56857)
Caterpillar Midi...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A58017)
2005 INTERNATIONAL...
