50 hr oil chainge
   / 50 hr oil chainge #1
Paddy
Bloomington, IN
Kubota, G5200, KAMA 454
Well it's been about a year I have had the KAMA 454 and it has reached the 50 hr mark. I will change the fluids as prescribed but wonder if the hydraulic oils need to be dumped. I thought I might be able to drain in to clean containers to let settle. Then pour through a tight mesh. I would completely flush the tractors system with Diesel fuel. I'd bet I'd be getting 98%.
The fluid looks as clean as when Chip put the new in, not the original China oil/sludge. It would seem the main points to hydro fluid changes are; removing metal shavings, water content and over heated oil that has lost it's good oil features. It's been stored inside most of the time, hasn't been worked more than 4 hrs at a time.
I supose as I drain it I might not be so set in my ways if what comes out looks prety bad. But just the idea that when I do drain it if looks new except for a bit of metal flakes....
What do you think? am I crazy to even consider this as an option?
   / 50 hr oil chainge #2
Yeah, just change it and the strainer element. You'll never worry about "did I do the right thing" for the next year. It's gonna cost you under a hundred bucks or so to do it.
   / 50 hr oil chainge #3
Yep.. draining to strain, and then refill.. that's alot of chances to introduce extra debri into the system..
Soundugy
   / 50 hr oil chainge #4
I too recommend changing hydraulic fluid/filter, and flushing never hurts. Chip and I bought a quantity of brass mesh to replace the OE suction filter, hopefully he's still got some left. If memory serves, it only takes a piece about 5"x7" wrapped around the existing core.
Don't forget that there's a paper filter element in the power steering reservior as well. I'd drain and refill that with new fluid as well. The AW32 was too thin for my steering pump, I've had to go to thicker oil (for steering only).
//greg//
   / 50 hr oil chainge #5
Greg,
Have you had this happen? At idle or lower rpms you turn the steering wheel and the wheels don't turn? Same under heavy fel loaded bucket. Then when I rev it up it starts to respond.
Is that something the thicker steering fluid will help? Is that what you are talking about?
Thanks,
   / 50 hr oil chainge #6
3RRL said:
Greg,
Thanks,
I have on my kama, the 30 wt fluid cured the problem.
   / 50 hr oil chainge
Greg,
When you did your flush with diesel fuel, did you run the lift?
   / 50 hr oil chainge #10
3RRL said:
Dwayne, 30wt fluid is AW-? what?
Thanks,
Greg said ISO 100 is approx 30/40 wt. The ISO 46 is approx 20 wt. I've seen I think ISO 68? here locally.
The place where I work has it in bulk. I just pumped a gallon out of the hose. So I didn't go back to look what was on the barrel. The guys in the shop just said this is 30 wt hydro here.
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
Deere 650J LGP (A50123)
Deere 650J LGP...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
