50 Hr Maintenance on M6800SD Tractor
   / 50 Hr Maintenance on M6800SD Tractor #1
W5FL
Central Texas
TYM T-1104/TX10 Loader Kubota M6800SD/LA1002 Loader Kubota RTV900
As part of the purchase price of the M6800 the dealer included performing the 50 hr maintenance including pickup and delivery.
I decided that I wanted to do it myself, so they furnished all the fluids and filters.
The M6800SD is a 2000 Model 68HP 4WD tractor with a standard Synchronized Gear transmission, shuttle mounted on instrument panel, and has wet disk brakes in the rear axle.
Used pressure washer to get dirt and grease off tractor. Warmed up the tractor by mowing a few rounds in 4WD and then put it in the barn.
Draining the oil was straightforward with 2 drain plugs that should have been metric but better fit 1 1/8 socket. They were tight. Caught the oil in 5 gallon bucket and caught 4 oz in analysis bottle. Let drain overnight. Removed Oil Filter. New Kubota filter was exactly same type and size. Refilled with 11 1/2 quarts of Kubota 15W45 engine oil using a funnel. The drained engine oil was moderately black in color.
Drained the transmission/hydraulics. Draining was straighforward with two with 2 drain plugs that should have been metric but better fit 1 1/16 socket. Caught 4 oz in analysis bottle. Took two 5 gallon buckets full to hold it all. A little tricky moving one bucket and getting the other one under it. Let drain overnight. Found a third drain plug not mentioned in the owners manual or shop manual. Removed two large hydraulic screw on filters. Cleaned the magnetic posts that go up inside one of the filters with clean shop towels. Could not detect any metal filings, but there were some very fine magnetic particles stuck to the magnets, although not enough to get back off a paper towel. Replaced both hydraulics filters. Refilled with 40 quarts of Kubota Super UDT using a funnel(Spec was 42 quarts - maybe there was a little fluid behind the third drain plug). The drained hydraulic fluid was medium brown in color. I expected it to be clear in color, but it was not. The new Super UDT was amber in color although it appears clear on the dipstick.
Drained the front wheel differential. The color of the fluid was light red and looked about like Dextron ATF fluid. Replaced with Super UDT and it held about 6 1/2 quarts (Manual says 5 1/2 quarts). Used a cheap rubber pump type oil pump. There is an extra fill hole in the center of the front axle that has a plug in it, but does not seem to be used or needed. Fluid did come back out when filling the front differential before it got up to the other filling plug. The bolt just below that is a long one and is NOT an inspection hole!
Drained both of the front wheel drive gear boxes. The color of the fluid was medium brown and almost identical to the transmission/hydraulic fluid. Each gearbox held the specified 3 1/2 quarts (total of 7 quarts) each of Super UDT. Used a cheap rubber pump type oil pump.
Found every zerk on the tractor and loader and greased with an air/grease gun and lithium grease (can you imagine a Kubota dealer selling BLUE grease?)
Cleaned outer air filter with air compressor. Removed and cleaned radiator screens although they really did not need it. Adjusted clutch, brakes, and front axle pivot pin. Loosened the locknuts on the PTO cover and oiled. Loosened the nut on the hook for the upper link storage holder and oiled.
Sent the two analysis bottles off to DARR Equipment Company. Saved a pint of each fluids to try to determine what came from the factory in each of the oil compartments. The biggest surprise was that they do not appear to be the same hydraulic oil in all compartments and the color was different. I don't know an accurate way of measuring viscosity of oils, but can compare with some other oils that I have. I will put this data in Oil and Lubricants section.
   / 50 Hr Maintenance on M6800SD Tractor #2
Now you can come to Cistern,Tx and do the 50 hrs maint.on mine,have 30+ hrs.on it now.Just kidding!I will do it myself.
Larry Schultz
There is plenty of room to use a creeper under the tractor or just crawl around on the floor. No harder than any other tractor to do the work yourself, then you know exactly what was done and how. Hope you like your M6800 as well as I do. No complaints so far. Just got the hydraulic top link mounted this weekend and then had to turn around and take it off to use a post hole digger. I was concerned with what to do with over 20 gallons of fluids, but the dealer will take all fluids and filters at no charge. That solved that problem.
   / 50 Hr Maintenance on M6800SD Tractor #4
Wen: did you change the hydraulic, gear, etc. fluids by choice or was it Kubota's recommendation? I'm curious because I just finished the 50 hour service on my TC and the only fluid the manual said to change was the engine oil. Changed all filters but the other fluids are to be changed at 300 hr. Maybe it also matters that mine's an HST. Don't know but I'll bet I can learn something!
That is Kubota's recommendation for 50 hours. I would have done it anyway as the first 50 hours are going to show any breakin wear. The majority of wet hydraulic clutch wear and disk brake pad wear takes place in the first 50 hours. Guess they just don't build Kubota's as tough as those BLUE tractors. /w3tcompact/icons/wink.gif I would think there would be more to wear on an HST than a gear transmission as several people have reported finding filings in the transmission oil at the initial hydraulic oil change. I am glad to get the Super UDT in now, but will probably put synthetic in on the next change as it is about the same price as the Super UDT and SHOULD be a better lubricant.
I just noticed that they also recommend cleaning the water separator at 50 hours (then at 400 hours). I have no idea why, but I will do it and then have to bleed the fuel system.
   / 50 Hr Maintenance on M6800SD Tractor #6
I am coming up on 30 hours on my 6800.I have about 18 hours bushhogging, the rest on moving 41/2 foot round bales.I dont know if it will handle the bigger bales but will have moved 385 of these bales by Sunday.It is running good.Only question is it whines a high pitch when in the highest gear.I will probably let the dealer do the 50 hour maintaince.
Should not have a problem with the larger bales if the tires are filled or you are carrying one on the back and one on the front. Otherwise that is a lot of weight and you will need something on the rear for counterbalance.
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
4 CYL ENGINE BLOCK & ENG STAND (A58374)
4 CYL ENGINE BLOCK...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
2006 Dodge Ram 1500 (A56858)
2006 Dodge Ram...
JOHN DEERE 12' BOX SCRAPE (A52708)
JOHN DEERE 12' BOX...
