50 hr hydraulic fluid change L4400
   / 50 hr hydraulic fluid change L4400 #1
spo307
Levittown & Long Eddy NY
kubota L4400
have 50 hrs. anyone know what type of fluid I need? we use a couple different ones at work
   / 50 hr hydraulic fluid change L4400 #2
Is it a HST or Standard Transmission? If it is a HST I would use the Kubota SUDT and if it is a Standard I would use the Kubota UDT or equal.
   / 50 hr hydraulic fluid change L4400 #3
If this is a 50 hour service, does mean your tractor is fairly new? Your operator's manual is valuable tool. I highly suggest you spend some time with it. I would guess that @ 50 hours, the recommendation is for filters only, not full fluid change, which saves you some money. Refer to the operator's manual and it's service recommendations for maintenance schedule.
   / 50 hr hydraulic fluid change L4400 #4
Kubota SUDT is speced in the manual. Personally, I use a generic UDT equivalent (from Sam's Club at ~1/4 cost of SUDT) in my L4200GST, which is pretty much the same machine. SUDT performs better in cold weather, so it's the by-the-book replacement for you, but I haven't had any issues using the cheap stuff.
JayC
its an HST, and 50 hours was for fluid and filter, I thought I remember reading gl4 for fluid, my manual is upstate with the machine, so I thought someone new what fluid, so I wouldnt have to go upstate then read then drive 30 miles to pick the fluid up, thanks for the help guys
thanks after reading the manual it was for filters only and motor oil $200 in all but cheaper than the 11 gallons of sudt i would have bought
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
2007 Deere 650J LGP (A50123)
2007 Deere 650J...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
