Oil & Fuel 50 hr check up
   / 50 hr check up #1
rlluellyn
ketchikan
Kubota BX-25
What does the kubota bx25 first 50 hr maintenance entail
   / 50 hr check up #2
I don't have your model. I have a Kubota L4400. It seems apparent that you are not in possession of the "Operator's Manual" for your tractor. I would advise you to acquire this manual. It will be quite useful in many ways. All the info that you are seeking is included in the manual. I have used my Operator's Manual countless times.There are several websites that you can order from. The cost is not that much, and is most certainly worth it. Best wishes.
   / 50 hr check up #3
I checked and that model is still in current production. If you don't already have the Operator's Manual, perhaps the parts department of your local Kubota dealer can order one for you. Just a thought? Best wishes.
   / 50 hr check up #5
For sure contact a Kubota dealer and get a Owners Manual for your BX25. They may even give it to you.
TripleR sent you a site in his post and I now have a BX25 and it's the same as the BX2660.
   / 50 hr check up #6
Yes, the owner's manual is very helpful...
   / 50 hr check up #7
You were given an owners manual w/ the tractor yes? I know
I am mimicing several others before me but it is an important document
and you should take the time to become aquainted with it, page
63 specifically regarding your request. The trans strainer needs
a heads up...you will drop ALL your expensive oil if you do not
plan ahead. A cork, or folks have used a vacuum to make a negative
pressure then pull the strainer, clean and replace.
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
John Deere 1025R (A53317)
John Deere 1025R...
2005 International 4300 Telsta Telescopic Bucket Truck (A55973)
2005 International...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
