50 Hr. Break-in Service on 4410
   / 50 Hr. Break-in Service on 4410 #1
Chief
Middle Tennessee
John Deere 4410
I am at 50 hours finally and am performing the 50 hour break-in service. So far I have done everything except the trans. filter/oil change and the 3 pt. hitch filter inspection. I have a 72" MMM installed and am considering whether or not to remove it for the service. On the one hand I hate to remove it cause it is not that bad but still a bit of work to R&R, but on the other hand not sure if I am risking getting oil all over the pullies and belts. Any of you done this service with the MMM installed? Thanks.
   / 50 Hr. Break-in Service on 4410 #2
I havnt broken the 15 hour mark yet. Woulnd you feel better if you got under the tractor and gave a good inspection to the under side, alot easier with the MMM out of the way.MHO
   / 50 Hr. Break-in Service on 4410 #3
</font><font color="blue" class="small">( I havnt broken the 15 hour mark yet )</font>
Wow, I am pushing 40... It won't be long till I'm doing the 50 hr thing...
Make sure you guys call ahead of time to the John Deere dealer for all the filters and parts. Mine did not stock the suction screen filter gasket. You can probably use the old gasket over again but did not want to take the chance of loosing 6.8 gallons of hyd. oil. I ordered all my spart belts, etc. too.
   / 50 Hr. Break-in Service on 4410 #5
I don't have a JD, but when I did my 150 service on my NH TC25D, it included greasing every zirk in sight, as did the 50 hour service (which my dealer did)! /forums/images/graemlins/smile.gif This was made much easier by having the mmm off. I could lay under the tractor (it sits high enough off the ground that I don't need stands or ramps) and look for, clean off and then grease all the zirks. There were zirks on the front drive shaft, the brake and clutch pivot points, etc., which were covered with just enough dirt that they were rendered invisible.
Without the mmm, I had enough room to actually have the manual with me under the tractor! I'd look at the manual to see where a zirk was supposed to be, find it, clean it off, grease it and see that the new grease was coming out of the fitting, then clean it off again.
My advice? Take the mmm off. It will make the job much easier and, as you surmised, you don't want to get oil on the mmm belts, pullies, etc.
BTW, having a cordless grease gun (Lincoln) also made this job much easier. No need to connect the hose (some zirks were not reachable with a fixed nozzle) from the grease gun and then hope it stays on while you use 2 hands to pump a standard grease gun. Just connect to the zirk with one hand and pull the trigger with the other. Alternatively, no need to use one hand to hold the nozzle on, find a place on the tractor to support the grease gun then use the other hand to press the lever.
2014 Mercedes GL550 AWD SUV (A56859)
2014 Mercedes...
2001 Dorsey 48ft Flatbed T/A Trailer (A56858)
2001 Dorsey 48ft...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2022 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2022...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
