50 Hour Service
   / 50 Hour Service #1
joeyd
Platinum Member
North Idaho
TYM 353HST
I am about to perform my 50 hr. service and I thought I would ask about a few "tips" to make it easier.
1. What do you use to catch the hydraulic fluid? My TYM has an 8.5 gal capacity but I have not seen anything larger than a 5 gal drip pan. Do you plug it and then dump your first 5 gals and continue? Doesn't this get messy?
2. Any advice on re-filling from a 5 gal container? Extra long funnel?
3. Has anyone used the Premium Tractor Fluid from Costco?
I have learned that it is better to learn from others mistakes whenever you can. I still make enough of them for all of us. :laughing:
   / 50 Hour Service #2
if you don't mind spending the money (assuming you'll continue to do your maintenance) NorthernTool has a few nice rolling oil trays that have a hand pump to drain in smaller containers. I got one that holds 17 gallons so it's good for both the engine and trans oil dump all at once. got these after a heck of a mess trying to swap out smaller oil pans while the oil was still running out. also have on hand a few oil soaking white pads - they really work along with the standard red shop towels. before the oil changes, i start collecting plastic bottles with lids (milk bottles, AZ tea, etc.) for transport to the local appropriate dumping station.
I've used the 5 gallon buckets to re-fill. could not find "one" filter that worked so had to prop up two filters - make sure they're good and tight and it was not a problem. those 5g buckets are lighter than i thought. seemed lighter than 5g of diesel.
   / 50 Hour Service #3
Run a quick search on the forums for 50 hour service. You will find several threads with tips and tricks. Foremost among them is a tip to use a shopvac to create sufficient vacumn to prevent the oil from draining while you change filters. :thumbsup:
You will likely get a rehash of many of these tips in this thread, but do the search while you wait. You will be surprised what else you may learn without having to think of the question first.
   / 50 Hour Service #4
Get some empty fluid buckets from a guy with heavy equipment they always have empties. Fill the first with about 5 gallons then quicly move the next under. Id personally chage this fluid over your gravel or in the grass so the spills dont get on your good floor. Then start up and move to your pad or shop for the oil as it is easy to catch. Forget the 1 gallon bottles to fill, just take the 5 gallon buckets with the oil in it with the original top to the collection center.
   / 50 Hour Service #5
Joeyd, for what it's worth when I did my 50 service on my B3030 Kubota I accidentally stripped the bolt threads when reapply the bolt when done. I had to get one of those thread repair kits for a little over $100. Talk about pucker factor! So my two cents worth just be careful so you don't over tighten any bolts when you reassemble. This is my 3rd Kubota and never had an issue with the other tractors so I'm kinda thinking I might of had a defective part, who knows?
   / 50 Hour Service #6
By chance did you have a copper or plastic washer on the drain plug?Usually it takes alot to strip a plug.
   / 50 Hour Service #7
A tip I used originally posted by dennis52 on another thread was to make a 15 gallon or so drip pan by cutting the bottom third from a 55 gal drum. It fits under the tractor and will handle the entire 11-12 gallons of fluid.
The drum I used originally contained hydraulic fluid so there was no explosion hazard while cutting it. If one uses a drum that contained volatile products care must be taken to ensure it is free of fumes.
For my Kioti DK35 HST, a 2 foot section of 1" flexible garden hose fits perfectly in the hydraulic filler opening and I shoved a medium sized funnel in the other end of the garden hose.
I placed all used fluids in another 30 gallon drum and will either take it to a local garage for disposal or use it for burning brush piles and/or as a coating as a rust inhibitor for long term storage of machinery.
   / 50 Hour Service #8
I don't remember having any kind of washer on the bolt. It's been awhile since I did the 50 hour service but when it is time to flush the system out you can bet I'll be extra careful when I tighten the bolt down. I had a Kubota B6200 (gear) and Kubota B1550 (HST) and never had an issue. I may have tightened it too much or maybe it was a defect, not that it matters since I fixed it with a thread repair kit.
   / 50 Hour Service
Thanks for the advice and Johnrex62 thanks, the other threads gave me more ideas.
One last question that no one answered was about the Costco Premium tractor fluid, any one use it yet?
   / 50 Hour Service #10
Menards and other big box home center stores sell what is basically advertised as a concrete mixing tub, for about $13, they are 2X3 feet and about 9 inches deep, black plastic. They work well for draining large amounts of fluid.
And, somebody mentioned here about stripped threads on a drain plug, reminded me of the issue I had with my Deere 4210. When I originally changed the hydro fluid and filters at the recommended 50 hours, the rear axle drain plug has a 3/8 inch square recess, and it wasn't hard to remove it with a socket wrench. I know I didn't tighten it very tight when I reinstalled the plug at 50 hours, but when I did the next fluid change at 500 hours, it was frozen in place and I was afraid of breaking it off while trying to loosen it, so I just backed the rear axle up on ramps to drain the hydro fluid when I removed the suction screen case. I still wonder if I should have put some kind of anti-seize compound on the plug before I reinstalled it.
2016 Ford F-150 Pickup Truck (A44572)
2016 Ford F-150...
2016 Case CX55B Midi Excavator (A45336)
2016 Case CX55B...
2004 Sterling Acterra 1,000 Gallon Water Truck (A45336)
2004 Sterling...
TAG 36in Excavator Bucket (A44391)
TAG 36in Excavator...
Ford NAA Jubilee Tractor (A46877)
Ford NAA Jubilee...
Pull-Behind 7-Reel Mower (A44571)
Pull-Behind 7-Reel...
