50 hour service
/ 50 hour service #1
garth466
Arlington, WA
John Deere 3120
How big a deal is it to get this right at the 50 hour mark? I just turned 50 and I may have another 15-20 hours before I'll be able to get it in. Do bad things happen say at 70 hours?
/ 50 hour service #2
I think you will be OK for another 20 hrs...
/ 50 hour service #3
I am waiting on delivery of a 2520. What exactly is done on the 50 hour service?
/ 50 hour service
I know the oil gets changed, which I guess I could do. Other than that, I think it is all spelled out under the hood. I kind of wanted to have the dealer do it for documentation and so I can watch everything they do (check, tighten, grease...). Maybe documenting the 50 hour at 70 isn't so good. It just seems very early to change the oil. Last I looked at it, it wasn't even that dark.
/ 50 hour service
I just called and they have time to do it in the morning and I can watch, so what the hay. The more I though about how much I will be using it in the next few months, the more it started to seem like it was going to have 150 hours for the 50 hour service. Better safe than sorry.
It still seems awfully early to have to change the oil.
/ 50 hour service #6
garth466
Just changing the "break-in" oil and hydrostatic trans fluid at 50 hours. I was pretty surprised at all the metal filings that were sticking to the magnets in the trans fluid. After that it is every 200 hours for my 2320. Pretty easy to do yourself just take John Deere's fluid capacities with a grain of salt and approach the full mark slowly.
/ 50 hour service #7
Does everyone switch to the low viscosity hydro oil after the first change?
According to the manual, it comes with the regular viscosity oil, but none of the dealers around here seem to carry it.
/ 50 hour service #8
EdC said:
garth466
That is why it is initially changed early, the break-in metal.I wouldn't let it go too long...
/ 50 hour service #9
Garth,
Check out this post: http://www.tractorbynet.com/forums/jd-owning-operating/109295-3320-unnecessary-50hr-service.html
If the service hasn't already been done, I suggest you look closely at what comes out of the front axle.
/ 50 hour service #10
Nice link with pictures Killer B! Looks like chips from machining something, not metal fragments indicating something wrong. But nobody wants to find that stuff in their oil.Let us know what you find in the next oil change.A magnet on the filler plugs sound like a good idea.
/ 50 hour service #11
I changed the fluids in stages: engine oil at 13 hours, 4wd gear oil at near 50, hydraulic oil at 50 or a bit higher. My used oil container only holds about 13 quarts. By doing in stages, it was enough. Just took it to an auto supply place and emptied it in between.
Hope your manual is accurate. On my 4010, it didn't tell me that one of the rear wheels had to come off to get at the hydraulic filter, which is behind the 3ph bar on which the lower lifts arms rotate from. The maintenance CD does tell that.
Ralph
/ 50 hour service #12
I have 1 year old 3320 with 100 hours. I did engine oil change at 50 hours myself. Took it to the dealership at 100 hours for the "100" hour service. All they did was change the engine oil again. Said that's all that is requred.
I have read my owners manual twice. No where does it say to change out "break in" oil or tranny fluid. Am I missing something???
/ 50 hour service
You aren't missing anything. I don't have it in front of me, but under the hood says change the hydro stuff at "a very long time from now". Same with the front axle. I changed the oil and had everything greased. I think I will ump on that other stuff before the manual says to, but not until the machine has a little rest. The trees started falling today.
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A61574)
2010 Mercury 15HP...
1989 Corvette Convertible (A61574)
1989 Corvette...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
2013 BMW 550i AWD Sedan (A61574)
2013 BMW 550i AWD...
2004 International 7400 C&C 017797 (A62613)
2004 International...
