50 hour service question.... Desperately need help
   / 50 hour service question.... Desperately need help #51
Air.. I can't believe you are using air.
Nitrogen is where it's at!!
Airplane tires, and nascar tires have it in them (no big pressure change with heat change)
Now the plane I fly can do 165 knots on the nitrogen filled tires.. I'm sure they will make the tractors go faster. Now.. convert that to MPH, or KPH for the chinese tractors.
Your up over 200!!
Now.. how many RPM's do you have to run your RFM at to make sure you get a good cut at 200MPH?
/forums/images/graemlins/smile.gif
   / 50 hour service question.... Desperately need help #52
JP11, You forget about the ground effect. The grass would be pushed flat on the ground !
   / 50 hour service question.... Desperately need help #53
One thing you may NOT have considered is whether or not the EPA is vigilant in enforcing clean air rules.
For example, a Manhattan resident might bring his/her tractor here to Colorado and find that they will incur a large expense for removing the Manhattan air and disposing of it properly, much like the fee for old A/C freon disposal. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2017 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A55851)
2017 Takeuchi...
Deere 335P (A53317)
Deere 335P (A53317)
1452 (A57192)
1452 (A57192)
1999 Ford F-450 Mason Dump Truck (A53422)
1999 Ford F-450...
2007 GMC C8500 Altec DL45TR Insulated Material Handling Digger Derrick Truck (A55852)
2007 GMC C8500...
