50 Hour Service on my BX1500
   / 50 Hour Service on my BX1500 #1
BIGUN
Tulsa, Oklahoma
Kubota BX1500
I did the 50 hour service on my BX1500 today; here are the things I learned…..
I found Tom’s BX-2200 50 hr service write-up helpful so I used it as a basis for detailing my experience with the BX-1500 50 hr service.
I started out by removing the MMM. It is very easy to remove and it is much easier working under the tractor with it out of the way.
To remove the engine oil filter I used a small strap wrench, the plastic type with a rubber strap. The filter was not on very tight and came off easily. A couple of black wiring harnesses run right across the center of the filter. I was able to lift the wires up slightly and hang them on parts above the filter. Some oil will get on the frame and will need cleaning off.
I put in 2.25 quarts of Rotella 15-40W oil. The book says it will take 2 quarts, must not include changing the filter. This put the oil level about ¼” below the upper hole on the stick.
Removing the transmission filter was not a problem; I was able to use an automotive filter wrench I had since the diameter of this filter is larger than the small engine filter. When installing the new filter hand tight the metal edge of the filter bottomed out on a nearby bolt head before becoming completely tight on the gasket. No leaks so far though.
I used the Blitz 15 quart drain pan to drain the transmission. It just barely fit under the housing. I wonder about the 15 quart capacity claim, my engine oil and transmission fluid completely filled the pans reservoir. I don’t think I drained more than 13 quarts.
I removed the transmission screen using a 26mm socket. I bought a ¾” drive socket set from Harbor Freight for about $35 since my 3/8” drive sockets didn’t go this large. The set has larger sockets to fit mower blade bolts also. My screen had a few fine metal pieces, cleaned it with a little regular unleaded, compressed air, and reinstalled. Care needs to be taken here to prevent damaging the o-rings. Remember you are working on an aluminum case, so go easy when tightening the screen bolt and drain plug.
To fill the transmission, I used an 8” plastic funnel with a 12” piece of clear ¾” vinyl tubing on it. I removed the upper 3pt link and used the small orange clip that holds it up to hold the funnel with the hose attached. It worked so well it was like it was made for that purpose. I was able to pour the 2.7 gallons of Super UDT from 2.5 gal jugs without spilling a drop. I was sure I would need someone to hold the funnel until I discovered the clip trick.
Reinstalled the MMM. I lower the lift all the way down then use the height knob set to “4” to hold the lift arms out of the way while I slide the deck under the tractor. Then I turn the knob to “0” to connect the arms up to the deck. Then hook up the front hangers and the drive shaft and it’s ready to go.
The engine oil was very black and dirty looking but the Super UDT looked so clean and clear that I can see why some dealers recommend just changing the transmission filter and leaving the fluid till the next scheduled change.
While under the tractor I discovered a diesel leak from the fuel tank in the area of the sending unit dripping down on the left axle housing. I guess this is the leaking sending unit problem I have read so much about. /forums/images/graemlins/frown.gif
   / 50 Hour Service on my BX1500 #2
I used the Rotella in my larger L3010, but my manual calls for 10w-30 in my BX2230. I would rather use the Rotella, what made you choose it?
I recall someone contacted Kubota and they said the owners manuals were a little behind the times and that the more common 15w-40 would be fine to use in the BX engines. Hope I recalled correctly. /forums/images/graemlins/crazy.gif
It doesn't get all that cold here and if it does I won't be out driving the tractor. /forums/images/graemlins/smile.gif
   / 50 Hour Service on my BX1500 #4
BigGun,
I remember the same thing. I also use the 15W-40, and I bet just about every one else around here does too, as it seems to be all that is commonly available.
Glad you remember it the same way Bill. I thought 15W-40 was what most have said they use. /forums/images/graemlins/smile.gif
   / 50 Hour Service on my BX1500 #6
Biggun,
If you don't mind me asking, how much did it cost for all of your materials for your 50 hour service?
arthurb
   / 50 Hour Service on my BX1500 #7
After talking with the mechanic at my dealer I believe either is ok. He said use he would 10w-30 but feels the Rotella is ok.
   / 50 Hour Service on my BX1500 #8
Yeah, it seems very wasteful to throw away gallons of transmission oil that's perfectly "clean". I wonder if that really is necessary.... it's a lot of oil to get rid of too, especially on the bigger machines like the L3130. I'm very tempted to skip my next change and just do the filter and screen. I guess the high level's of oil maintenance is just a big negative of HST transmissions... you can leave ATF in your car for 100K miles! (or more).
- P
Sorry about being slow to answer, but I just got back from a trip to Columbus, OH.
These are the supplies I used and their approximate cost:
Kubota Super UDT - $34
Rotella - $4
Trans Filter - $16
Oil Filter - $8
Shipping - $6
12” Vinyl Tubing - $2
Total - $70
I can’t see where it would hurt to just change the filter and not change the transmission oil until the second scheduled interval (300 hrs, I think) based on how clean the oil looks. There is likely more to it than just being clean, like heat deteriorating the oil, but it seems like it should be good for more than 50 hrs and the oil would darken some if it has been too hot. On the BX, being able to remove and clean the screen without dumping the oil would be a problem.
YANMAR YT359 TRACTOR (A51247)
YANMAR YT359...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
NEW Woods Reverse Rotation 5ft Tiller (A53472)
NEW Woods Reverse...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
