50 hour service cost
   / 50 hour service cost #21
John, I finished the 50 hr on my L3010HST last month. I went to the dealer and told him I wanted everything to complete the service. What he provided me was 80W-90 for the front axle although what came out looked like UDT.
You're right, the screen is a bear to get out. I not only had to disconnect the spring you talked about but also disconnected a hydraulic line in order to get enough clearance to remove the screen with out trying to force it pass anything.
Rick K.
   / 50 hour service cost #22
<font color=blue>just how does one deal with 4 or 5 gal of fluid?</font color=blue>
I don't really know, except that I've got a couple of 5 gallon drums left over from other stuff. That would probably be what I used if forced into a corner... /w3tcompact/icons/crazy.gif
The GlueGuy
   / 50 hour service cost #23
For about 30 bucks or so, I picked up an industrial-sized drain pan from NAPA Auto Parts. I think it holds about 7 gallons, which is cutting it pretty close on my L2500, but since I can't get every last drop all at once (4 drain plugs), it worked out just fine.
I was, in fact, able to get all the drained fluid into the pan, so when I was all done putting the new fluid in, I poured the old oil into the newly-emptied oil jugs. Of course, then I wound up driving these jugs all the way back home (120 miles) 'cuz there are more accessible recycling centers around here.
If you're into visuals, I have a section on my web site showing the whole process I went through. Look under the Maintenance / Hydraulic Fluid section. /w3tcompact/icons/smile.gif
2020 FREIGHTLINER M2 SERVICE TRUCK (A58214)
2020 FREIGHTLINER...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2007 NEW HOLLAND B95 BACKHOE (A52709)
2007 NEW HOLLAND...
