50-hour service and engine oil grade
   / 50-hour service and engine oil grade #21
I thought CH-4 was the newest rating for the oil./w3tcompact/icons/wink.gif
Bird
   / 50-hour service and engine oil grade #22
Bird I've seen F but no H's on the jugs we have here, they may be labels printed before the new ratings.
   / 50-hour service and engine oil grade #23
<font color=blue>they may be labels printed before the new ratings</font color=blue>
Probably, Art. I'm using Chevron's Delo 400 15W-40 and the container shows API ratings CH-4, CH, CG, CF (and I've forgotten what else) on one side and on the other is a label that says "Exceeds CH-4 Performance".
Bird
   / 50-hour service and engine oil grade #24
This attachment is from the API website. The CF rating is the current off-road, high sulpur diesel oil rating. There are 4 other ratings up to the CH-4 rating which is the highest rating for high speed diesels.
Joe
<P ID="edit"><FONT SIZE=-1>Edited by Joesgoats on 08/14/01 12:50 PM (server time).</FONT></P>
   / 50-hour service and engine oil grade #25
John,
You have me thinking about hydro fluids. In the past, several people have said that they found a fair amount of metal filings on their strainers at 50 hrs. Would the filings to small to be hung up in the strainer be a bad thing to leave in the system? If so, would it be possible to drain, filter and reuse the fluid? I know it would be a mess, but at $20 per gal. it might be worth doing. I would agree that the fluid should last well over 50 hrs if it were not for the metal filings.
MarkV
   / 50-hour service and engine oil grade #26
Mark,
First, if I found minute particles of metal in my filter... I'd be very unhappy...{You'd have to think...what is wearing... where is it coming from... not normal} I've never ever had it happen on any gear tractor I've owned.
I would certainly change all the hydraulic fluid with new fluid... never used. You can choose between $4 or $20./gal...
That's why God gave us choices... You don't have to buy the $20./gallon hydraulic fluid because the can/jug matches your tractors color. I have to trust the manufacturer of the $4. /gallon fluid because his label is certified by the API and clearly states it's an equivalent fluid for my JD, NH, Massey, Kubota or whatever... {I've been trusting the labels for years... hasn't failed yet}
So whether it's fluid in 5 gallon pails from Sams Club, Walmart... I'm not brand loyal... as long as it meets the spec's and so states.
On the other hand, if you're bringing your tractor down to Byrd Station, Antarctica, you may want to consider the $20./gallon synthetic fluid that will flow @ -38 degrees...{the normal $4.gal. is only good to -34 degrees} /w3tcompact/icons/smile.gif
   / 50-hour service and engine oil grade #27
Sorry John Miller, III,
You don't have to go that far to get -38, just come up to Winnipeg in the end of January, beginning og February and it will be as cold.
That why there are so many Snowbirds, my Dadis one, flockig down to Arizon and similar warm states.
Merry Christmas.
Winnipeg, Manitoba
2001 BX2200 (26 hrs)
   / 50-hour service and engine oil grade #28
Steven,
What do you feed this goose...
Man... he keeps flying and flying and.... /w3tcompact/icons/smile.gif
   / 50-hour service and engine oil grade #29
John,
We don't have to feed hiim anythink.
If you saw -38 coming you'd flap just as hard and just as fast in the opposite direction.
Winnipeg, Manitoba
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
1991 TRAILMASTER CRUDE TRAILER (A58214)
1991 TRAILMASTER...
2025 ZJG ZJ-13 Mini Excavator (A56857)
2025 ZJG ZJ-13...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
