50 Hour Fluid change on 3130
/ 50 Hour Fluid change on 3130 #1
johnk
Elite Member
western NY
Kubota GST Grand L3130 w/ 723 loader, Ags
A little expensive but had to be done.
A picture of the Hydraulic filter with quite a bit of debris on the what I believe is a magnetic ring...
Didn't really make a huge mess. A few splashes here and there....
Now I have piece of mind.........I also changed the front axle fluid and it didn't look bad at all. I put regular UDT in there. I also changed the engine oil last week along with oil filter.........
/ 50 Hour Fluid change on 3130 #2
Be sure to re-check your ft. differental fluid level in a few days, when I did my 50 hr. srvice I drained it and all that good stuff and re-filled it then the other day I re-checked it after alot longer than a few days and was suprised to see it take a little over two quarts, the manual says it holds 4.8 but you can't call the manual gospel when it comes to capacities.
It is weird I know and my tractor Is a L2800.
/ 50 Hour Fluid change on 3130 #4
chrisjbell said:
That sounds like a leak if you put 4.8 or so in it when you refilled it. Keep an eye on it...
Nope... no leak...I put a little over 2 Qts in and it holds 4.8 per manual, the axle is dry as dry can be.
A friend of mine has a L4330 and I called him to tell him my story and he pulled the level check plug on his tractor and started putting oil in till he put in 4 Qts...his ft. axle supposidly holds 9.5 qts.
I belive the tolerances in the gears and bearings hold the oil back till it can drain into all the little places.
Took it for a ride around the yard and rechecked. Still up to snuff.....
/ 50 Hour Fluid change on 3130 #6
I remember when I went into the dealer and asked for the fluids for my 50 hour sevice. I almost passed out when she pulled out two 5 gallon buckets of SUDT from behind the counter! I think it would have been easier to handle the fluid if I had the option of the smaller containers you had.
The debris on your magnetic ring is shavings from the transmission gears. I had the same thing on mine. It worried me at first, but the dealer and the manual said it was to be expected.
For my front axle, I just put in the amount it said in the manual. I let it set for a while, then drove it around easy. The next day I checked the fluid level and it was pretty much right on. The dealer gave me the 80W gear oil to use, and said it takes this stuff a little while to settle in. I also found it is really important to get your front axle completely level when you fill it and check it. Just a little tilt really skews the level of the fluid.
/ 50 Hour Fluid change on 3130 #7
I just did the "50 hr service" on mine after 100 easy hrs:(
I had about the same gunk on my filter magnet. I did super UDT for the tractor and I also bought regular UDT for the front axle.
I did the math it was cheaper than gear oil, and easier to drain, and fill.
Tractor does feel a bit smoother after the fluid change. Could just be me.
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
2012 International 4300 Reefer Truck (A63689)
2012 International...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
2022 EZ-GO ELITE...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
