50 hour fluid and filter change cost?
   / 50 hour fluid and filter change cost? #11
You simply can’t pay a mechanic enough money to care about your equipment as much as you do.
If you could be a fly on the wall at a dealer and hear what the techs say about the customers, watch how the lot jockeys move your hardware around, and witness the BS for yourself… you’d never use a dealer.
Someday I’ll be too old. A couple weeks ago I hurt pretty bad after rolling around with a transmission and transfer case, after installing a clutch in one of my trucks, but it was worth it to get it done right and not have some fool attempting it after a couple bong rips at lunch.
I replaced a transmission mount and fixed a vacuum leak while I was under there too. Then I replaced all the hydraulic master and slave cylinder assembly. Chased the threads on the old bolts, installed new bolts on the exhaust collectors because the old ones were questionable. I probably saved over $1000 in labor.
Maybe a really good private mechanic, a 1 in 100 guy will be that diligent.
But I doubt the senior tech at the dealer is doing the lube jobs. It’s usually the stoned kid.. and he’ll strip your drain plug threads and get fired from 2 more jobs before you ever find out what he did.
I am having trouble figuring out what type and brand of hydraulic fluid to use. TYM is specifying "API GL-4 Grade".
Some people recommend Traveler Universal Premium Tractor Fluid, but on the other hand I read elsewhere that this is not appropriate for hydrostatic transmissions. The gear oil for the front axle and the oil for the engine seem pretty cut and dried, but I am stumbling on this hydraulic fluid choice. I sure don't want to use the wrong stuff and run afoul of a warranty issue if one crops up in the next several years.
Any advice?
I finally settled on Shell Rotella T6 15W-40 full synthetic for engine oil, Lucas Synthetic Universal Hydraulic Fluid 10100, and Amsoil Severe Gear synthetic 80W-90. I have the filters that I picked up from my dealer, and just waiting for the Amsoil to come in.
Gleaner N630 Corn Head (Allis Chalmer Branded) (A55302)
Gleaner N630 Corn...
12in Digging Tooth Bucket Excavator Attachment (A53421)
12in Digging Tooth...
2239 (A51244)
2239 (A51244)
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
CATERPILLAR 246D3 SKID STEER (A52707)
CATERPILLAR 246D3...
2001 Blue Bird Commercial Portable Office Bus (A55852)
2001 Blue Bird...
