50 HOUR 1540 HYDRO
   / 50 HOUR 1540 HYDRO #1
coolhl7
Panhandle Florida
MF1540HST
Is there anything tricky about doing the 50 hour?
just change engine and transmission oil and filters,
checking the fuel filter, greasing zerks, and checking bolts for proper torque.
Is there really anything else they do at the shop that I couldn't do or that is tricky??? Thanks
   / 50 HOUR 1540 HYDRO #2
I did my own 50 hr service on a 1533 and all went well. Its a great way to get familiarized with your new tractor!
The only thing that took a while to find were the two zerks located under the rubber matt on the operator platform.:eek:
   / 50 HOUR 1540 HYDRO #3
Were yours a pain to grease also? I greased them, but like to have never got the hose off the clutch side after I greased it. There's not a lot of room under there.
   / 50 HOUR 1540 HYDRO #4
Yes, they were. I could not get my greese guns tip to get around the Zerk so I decided to replace the original zerk with on that had an angle on it and here is how it went: One hour getting the original one off, one hour trying to get the new on (and failing) and two hours getting the original one back on..don't try this aggivating exercise at home:rolleyes:
My final solution was to grind the access hole slightly larger, which worked. I could have avoided the hole thing by finding one of those "specialty" tips for my greese gun. Besides those two zerks, the 50 Hour service went smooth. :D
   / 50 HOUR 1540 HYDRO #5
Well as long as it did not take 50 hours to do the 50 hour service, you did well.
Thanks,
Will
   / 50 HOUR 1540 HYDRO #6
Be careful changing the fuel filter...I have had a problem ever since. Looses power and puffs of white with a faint fuel smell. I have tried to bleed, cracked the injectors, but I am wondering if fuel is not getting to the filter in a timely manner...beats me but I am very aggravated.
   / 50 HOUR 1540 HYDRO #7
I've seen a Massey do similar things because the upper gasket for the fuel filter was installed incorrectly. If your tractor has the canister type filter with a gasket on top and bottom there is a good chance that is the problem. The tractor I looked at just had a filter put on it and the upper gasket was sitting inside the lip of the filter partially blocking off fuel. The gasket actually sits on the very top of the filter.
Reversible Plate Compactor (A50121)
Reversible Plate...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
NEW Ripper Shank (A53002)
NEW Ripper Shank...
Two Post Car Lift (A50121)
Two Post Car Lift...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
