50 acres of High tensile
   / 50 acres of High tensile #1
Gizmo36
Platinum Member
East of Duewest S.C.
I am fencing in 50 acres of High tensile . Well it is 196 acres but I am only doing 50 acres at a time. I am going to take some pictures as I go .I am not trying to make it pretty . Just trying to put up a fence and I am slow.
More pictures
   / 50 acres of High tensile #3
I would consider using some diagonal brace wire to keep the corner post from rising, and it will also keep your brace and cross post tight.
   / 50 acres of High tensile #4
Mighty fine looking to me. Keep the pictures coming.
Bentwrench I am going to put some diagonal on them . I am just slow to getting there thank you dabear.
   / 50 acres of High tensile #6
Your cedar crossbraces look solid. I would say you are off to a good start.
When you put your diagonal brace wires on, consider runming them both ways >< that way you can pull your wire from both directions.
   / 50 acres of High tensile #7
Looks great sure wish I had cedars around my place to use for corners and braces. Seems like everything here in florida either eats wood or rots it..............
   / 50 acres of High tensile #8
Do you have any idea on how long the cedar is going to last?
I have piles, and I mean piles of ceder. And more that have to be cut up due to snow/ice damage. I see some cedar fences but they all seem to be falling down. I don't know how long the fences have been up though, 1 year or 50 years.
Later,
Dan
   / 50 acres of High tensile #9
Later,
Dan
Debarking the cedar will help longevity. Bark will come off with a 2500 psi pressure washer if you let freshcuts season for 6mo. Green takes more pressure.
larry
Weldingisfun I am on some , That is a nice Billy in your picture. That is what the fence is far I want one that looks like that. Firemen122 I have about 10 acres in cedars. Dmccart I have some that has been in the ground for 40 years and they are ok. They need a good heart to last long. Spyderlk I did not know that I will keep some back and try that. I started to get a sawmill and cut them up square .
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
2015 VOLVO L90H WHEEL LOADER (A52705)
2015 VOLVO L90H...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
40' SHIPPING CONTAINER (A53843)
40' SHIPPING...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2013 FREIGHTLINER...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
