50 acres of High tensile
   / 50 acres of High tensile #1
Gizmo36
Platinum Member
East of Duewest S.C.
I am fencing in 50 acres of High tensile . Well it is 196 acres but I am only doing 50 acres at a time. I am going to take some pictures as I go .I am not trying to make it pretty . Just trying to put up a fence and I am slow.
More pictures
   / 50 acres of High tensile #3
I would consider using some diagonal brace wire to keep the corner post from rising, and it will also keep your brace and cross post tight.
   / 50 acres of High tensile #4
Mighty fine looking to me. Keep the pictures coming.
Bentwrench I am going to put some diagonal on them . I am just slow to getting there thank you dabear.
   / 50 acres of High tensile #6
Your cedar crossbraces look solid. I would say you are off to a good start.
When you put your diagonal brace wires on, consider runming them both ways >< that way you can pull your wire from both directions.
   / 50 acres of High tensile #7
Looks great sure wish I had cedars around my place to use for corners and braces. Seems like everything here in florida either eats wood or rots it..............
   / 50 acres of High tensile #8
Do you have any idea on how long the cedar is going to last?
I have piles, and I mean piles of ceder. And more that have to be cut up due to snow/ice damage. I see some cedar fences but they all seem to be falling down. I don't know how long the fences have been up though, 1 year or 50 years.
Later,
Dan
   / 50 acres of High tensile #9
Later,
Dan
Debarking the cedar will help longevity. Bark will come off with a 2500 psi pressure washer if you let freshcuts season for 6mo. Green takes more pressure.
larry
Weldingisfun I am on some , That is a nice Billy in your picture. That is what the fence is far I want one that looks like that. Firemen122 I have about 10 acres in cedars. Dmccart I have some that has been in the ground for 40 years and they are ok. They need a good heart to last long. Spyderlk I did not know that I will keep some back and try that. I started to get a sawmill and cut them up square .
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
2006 FORD F-250 (A53843)
2006 FORD F-250...
BACKHOE BUCKET (A53843)
BACKHOE BUCKET...
Informational Lot - Financing (A53473)
Informational Lot...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A53843)
HYDRAULIC AUGER...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
