5 wire boat trailer
   / 5 wire boat trailer #1
bucktaker
Platinum Member
Sw Ohio
Kubota L5740
just picked up my new to me boat...... I had only glanced at the connector and saw it was flat so I thought no problem....hooked it up me 4wire boat 5wire,,,,only had 25 miles to transport. got gas in the boat and found seat cushion had blown out and back tracked to storage lot to find it...never did find it
I suddenly found couldnt back up the trailer because the 5th wire wasnt connected. I finally figured it out that I needed 12vdc applied to the 5th wire to back up.
is there away to disable this on the trailer side without converting to a 5 wire? Of course its memorial day weekend and we are at the lakehouse so access to a parts house to buy a converter is not likely to happen
If i run a hot wire from the battery to this wire for the weekend will brakes work forwards?
surge brakes
   / 5 wire boat trailer #2
That must tie into the reverse lights, is my guess. So when you reverse the brakes do not activate, but will work at all other times in forward motion. I would not run an always-on hot to it. Really should go to reverse light hot.
   / 5 wire boat trailer #3
s219 is right. Run a feed wire from backup light on tow vehicle to that 5th wire.
   / 5 wire boat trailer #4
Flip the plug upside down and replug it when backing down should work. my trailer does. they make different adapters for four to five plugs
thanks flipping the 4 way worked
   / 5 wire boat trailer #6
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
2011 JLG 6042 TELESCOPIC FORKLIFT (A51246)
2011 JLG 6042...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
