Rear Blade 5' Rankin rear blade on 15 HP Kubota; too much?
   / 5' Rankin rear blade on 15 HP Kubota; too much? #1
AKFord
5\' Rankin rear blade on 15 HP Kubota; too much?
I am debating on getting a 5' Rankin rear blade but am wondering if it is too much weight for a 15 horse tractor, the Kubota BX 1500. The blade weighs 255 lb which seems like an awful lot, I plan to use it mostly for clearing snow and I wanted to get the 5' instead of a lighter weight 4' so I have more coverage when the blade is angled. If anyone thinks the Rankin blades are decent products and/or think that size blade is too heavy for my tractor please let me know. Thanks for your time, it is appreciated!! 5'
   / 5' Rankin rear blade on 15 HP Kubota; too much? #2
Re: 5\' Rankin rear blade on 15 HP Kubota; too much?
I don't know anything about Rankin blades, but I can say that I have a 5' heavy duty (weighs about 300+ lbs) Deere rear blade behind my 19hp B8200, and that works just fine for scraping gravel, clearing snow and whatever. Of course, I have a 500 lb FEL on the other end.
   / 5' Rankin rear blade on 15 HP Kubota; too much? #3
I used a 5' Woods blade on my old B7200 (17HP) and it did fine, but it was a heavier tractor too. As long as you aren't trying to cut with it or take a huge mound of material you should be ok, but the clearance at its fully raised height may get you as well. Good luck.
   / 5' Rankin rear blade on 15 HP Kubota; too much? #4
You can probably use the 5' for light & loose materials, but I think you will get stuck if you try to grade a ditch or some other work where the blade actually engages the ground and needs to moved undisturbed soil.
   / 5' Rankin rear blade on 15 HP Kubota; too much? #5
<font color="red"> If anyone thinks the Rankin blades are decent products </font>
I have a rankin 4' box blade and think it is a quality implement.
   / 5' Rankin rear blade on 15 HP Kubota; too much? #6
I have a 36" Land Pride tiller on my BX1500 right now. It is much heavier than a blade. The BX handles it without any trouble at all.
I also have been using a borrowed 5' landscape rake that is very similar to a rear blade except with spring tines. Your BX1500 can do just about anything you ask of it. The only thing that still bothers me is the more confident I get the more cocky I get. I've almost dumped it over a couple of times in the past month!!!! I gotta slow down.
   / 5' Rankin rear blade on 15 HP Kubota; too much? #7
I have a 5' blade on a 16HP Ford 1210. Works like a champ for snow removal. I prefer to have a blade that clears a path wider than the tractor when the blade is angled. My 21HP B7500 has a 6' blade and it works fine too.
If you get a great deal on a 5 footer and are unsure about the length, you could trim a few inches off the ends..................chim
Thanks for everyone's excellent input! I decided to go with the 5' Rankin blade with the idea that snow removal would be it's main duty; this is my cheaper alternative to a snow blower which I will save up for. In addtion, I will be able to do the obvious tasks of spreading crushed rock/gravel and do a little bit of grading. Thanks again, due to the input here and from a call to Rankin I decided that was the way to go.
2021 Chevrolet Equinox LS SUV (A55853)
2021 Chevrolet...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2017 Bobcat T770 Compact Track Loader (A55314)
2017 Bobcat T770...
2022 CATERPILLAR 299D3 SKID STEER (A52707)
2022 CATERPILLAR...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A55852)
2012 Crane Carrier...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
