Rear Blade 5' Rankin rear blade on 15 HP Kubota; too much?
   / 5' Rankin rear blade on 15 HP Kubota; too much? #1
AKFord
5\' Rankin rear blade on 15 HP Kubota; too much?
I am debating on getting a 5' Rankin rear blade but am wondering if it is too much weight for a 15 horse tractor, the Kubota BX 1500. The blade weighs 255 lb which seems like an awful lot, I plan to use it mostly for clearing snow and I wanted to get the 5' instead of a lighter weight 4' so I have more coverage when the blade is angled. If anyone thinks the Rankin blades are decent products and/or think that size blade is too heavy for my tractor please let me know. Thanks for your time, it is appreciated!! 5'
   / 5' Rankin rear blade on 15 HP Kubota; too much? #2
Re: 5\' Rankin rear blade on 15 HP Kubota; too much?
I don't know anything about Rankin blades, but I can say that I have a 5' heavy duty (weighs about 300+ lbs) Deere rear blade behind my 19hp B8200, and that works just fine for scraping gravel, clearing snow and whatever. Of course, I have a 500 lb FEL on the other end.
   / 5' Rankin rear blade on 15 HP Kubota; too much? #3
I used a 5' Woods blade on my old B7200 (17HP) and it did fine, but it was a heavier tractor too. As long as you aren't trying to cut with it or take a huge mound of material you should be ok, but the clearance at its fully raised height may get you as well. Good luck.
   / 5' Rankin rear blade on 15 HP Kubota; too much? #4
You can probably use the 5' for light & loose materials, but I think you will get stuck if you try to grade a ditch or some other work where the blade actually engages the ground and needs to moved undisturbed soil.
   / 5' Rankin rear blade on 15 HP Kubota; too much? #5
<font color="red"> If anyone thinks the Rankin blades are decent products </font>
I have a rankin 4' box blade and think it is a quality implement.
   / 5' Rankin rear blade on 15 HP Kubota; too much? #6
I have a 36" Land Pride tiller on my BX1500 right now. It is much heavier than a blade. The BX handles it without any trouble at all.
I also have been using a borrowed 5' landscape rake that is very similar to a rear blade except with spring tines. Your BX1500 can do just about anything you ask of it. The only thing that still bothers me is the more confident I get the more cocky I get. I've almost dumped it over a couple of times in the past month!!!! I gotta slow down.
   / 5' Rankin rear blade on 15 HP Kubota; too much? #7
I have a 5' blade on a 16HP Ford 1210. Works like a champ for snow removal. I prefer to have a blade that clears a path wider than the tractor when the blade is angled. My 21HP B7500 has a 6' blade and it works fine too.
If you get a great deal on a 5 footer and are unsure about the length, you could trim a few inches off the ends..................chim
Thanks for everyone's excellent input! I decided to go with the 5' Rankin blade with the idea that snow removal would be it's main duty; this is my cheaper alternative to a snow blower which I will save up for. In addtion, I will be able to do the obvious tasks of spreading crushed rock/gravel and do a little bit of grading. Thanks again, due to the input here and from a call to Rankin I decided that was the way to go.
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
Massey Ferguson 9250 (A53472)
Massey Ferguson...
1995 GMC CHIPPER/BUCKET TRUCK (A52576)
1995 GMC...
2021 Chevrolet Silverado 4500HD / Silverado 5500HD Flat Bed, VIN # 1HTKJPVK3MH814615 (A51572)
2021 Chevrolet...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
