Tractor Sizing 5 ft implements
   / 5 ft implements #1
deerfarmer
piedmont nc
hey, for the experts,what hp tractor will handle5 ft implements ,or what is thesmallest size tractor you would use. not brand specific,will consider all thanks!:confused::confused:
   / 5 ft implements #2
It really matters what type of 5' implement. A 5' bush hog or finish mower will take more tractor than a 5' cultivator, post hole auger, etc. But I'd say roughly that your 3pt. "stuff" is generally ok if not much wider than the tractor.
   / 5 ft implements #3
About 25 PTO HP should do well for you.
Smaller, or less HP< and you might need to slow down on occasion.
Really depends what implements you plan to use.
2019 GEHL RT105 SKID STEER (A52707)
2019 GEHL RT105...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
2021 International MV607 S/A Dump Truck (A55852)
2021 International...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
(4) Roadguider ST235/80R16 Tires (A56469)
(4) Roadguider...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
