Buying Advice 5 foot rotary cutter..
   / 5 foot rotary cutter.. #1
gravelman
Platinum Member
NH
Kubota 2650
Hi folks...gravelman here..hope you are all safe and healthy im looking for advice on buying a 5 foot rotary cutter brush hog. I have had JD, Bushhog and Befco.. i have a 4 foot Befco but blades are difficult to change. Im a one person show. So im looking for something that is EASY to change blades and can stand some rough use. i hook up to a Kubota 2650 thanks
   / 5 foot rotary cutter.. #2
I don't know what you mean by easy, They are all about the same on the newer mowers cut out on the top of the deck the get to the blades, Woods has a keyhole keeper with a small bolt to hold it in I just got a BB60X but have not changed or sharpened the blades.....
ok im not familiar with the keyhole keeper but i will look into it.. that must make it a bit easier... thanks
   / 5 foot rotary cutter.. #4
   / 5 foot rotary cutter.. #5
Deere might makes a bolthole to remove blades on their smaller mowers. Most bush hogs are pretty much the same, but Deere offers a double deck design. Theres an upper sheet metal top and a lower metal layer to absorb the dents. My big Deere CX-15's are 5 years old. Paint looks excellent and no "bumps" from rocks or stumps in the sheet metal. I had Woods units prior to that and after a few years, they had bumps all over the decks, the paint cracked and they rusted. Full disclosure-I cut some rough ground. If you dont, a single deck layer may work out for you.
ok on both counts..thanks for the diagram..i you tubed Woods and there is a blerb about new features but it did not demonstrate how the blade change goes...except to say it is easy and can be done in the field...i guess i will stop at dealr and take a close look...
   / 5 foot rotary cutter.. #7
I will Anti-Seize the pins soon so it will come apart when I have a chance...:)
did you say NEVER??
yes, never seize is good stuff
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2017 Ford F-350 Flatbed Service Truck (A56858)
2017 Ford F-350...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
