5 foot rotary cutter on B7800 ?
   / 5 foot rotary cutter on B7800 ? #1
Ed_C
Southwick, MA
Would I have a problem with a RCR 1860 on a B7800. Both in terms of lift weight and cutting power? Mainly to be used to keep my woods edge clean in my fields. Have a lot of viny growth like Oriental bittersweet. Some mountain laurel.
If I dropped down to the 1548, anyone see any problems there? Durability?
While I'm at it, looking at a Wallenstein BX42 chipper. Haven't read much here about them.
Package
B7800 HSD
Loaded R-4's
LA402
Toothbar
weightbox
60 inch rear snowblower
Wallenstien Bx42 chipper
RCR1860 rotary cutter
$24,150 delivered
   / 5 foot rotary cutter on B7800 ? #2
Ed, I can't say I've had any personal experience with that combination of tractor and rotary cutter, but I wouldn't hesitate to use that at all. I think it would be a good combination; B7800 and RCR1860.
   / 5 foot rotary cutter on B7800 ? #3
I personally wouldn't use anything smaller. I know it isn't conventional thinking around here but I pull a 5' with my 18hp B7410. It does fine and really doesn't have any trouble even with pretty heavy stuff. I can't just fly through everything and of coarse a little common sense goes a long way.You'll have 7 more hp at the PTO so I can't imagine it'd be a problem at all.
   / 5 foot rotary cutter on B7800 ? #4
I use a 5' Land Pride rotary cutter behind my B7800--never had a problem keeping up the RPM's in thick weeds, tall grass or brush.
Regards, Mike
   / 5 foot rotary cutter on B7800 ? #5
Hi Ed,
I pull a 5' hog behind my B7800, down into a hollow and back up and out. Absolutely no issues as far as power. I do use my LA 402 front loader as ballast, though I took it around the edge of my field last week without the front loader. It just made the front end a little light. If you get anything smaller you'll regret it.
Pat
Thanks! Dealer said 5 ft cutter was fine. Just was kind of intimidating looking at 600 lbs of metal standing on it's end like that.
   / 5 foot rotary cutter on B7800 ? #7
The JD 513 60" Rotary I have can bog my B2910 (same tractor as B7800) down in heavy tall grass. I would still buy a 60" cutter. It covers tires on both sides. Just slow down or cut a smaller width when engine starts to bog down.
   / 5 foot rotary cutter on B7800 ? #8
I use a Woods BB60X behind my B-7800 with no problems whatsoever..
   / 5 foot rotary cutter on B7800 ? #9
I have been running a Woods BB60 on mine for years. I keep the FEL on for counterweight and in mid-summer I can mow in High. I have nice flat land.
Good luck with yours!
-Mike Z.
   / 5 foot rotary cutter on B7800 ? #10
I run a Woods 60" behind my B7800 and I use it in the woods as well as my fields. The tractor handles it OK, but I take it easy when I'm in the thick stuff, and when I have it up in the air. I have a FEL for some counter weight. I wouldn't go any smaller.:)
2008 FORD F-350 (A52472)
2008 FORD F-350...
2019 MITSUBISHI OUTLANDER SPORT (A52472)
2019 MITSUBISHI...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
APPROX 21 SIDEWINDERS (A52472)
APPROX 21...
LOT LOCATIONS (A52577)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
