Craig Clayton
Platinum Member
Gentlemen
I own a 5"chipper that I have used for many hours but wish to power it by a garden tractor. I plan to use it 2 hours distant and do not want to move the Kubota.The JD has 19.5 HP engine vertical shaft and the mower belt pulley will accept a B belt. The belt is called a green belt ( high flex) at 127 " long. The chipper had the pto pulley unbolted and the idlers bolted on. The first set of wheels have been beefed up. Chipper runs at 2000rpm input at 20 HP.The tractor is brought up to the chipper and turned off and belt jumped up on to the pulleys and restarted and an adjustment screw slowly moves the tractor back 1" as you raise the speed to full engine 3400 rpm . As I know the sound of the chipper I ran a trial sample through it in my shop ( big mess ). The tractor can also sneak into a backyard with the chipper in tow. I have the belt running through( 2 ) 5" V belt idlers and (2 ) 4" back idlers with guide fingers made from the same 5/16 round steel that holder industrial dirty laundry bags. The idlers run at angles that I used a steel wedge to adjust. If there are any questions I will try to respond.
Craig Clayton
Craig Clayton
