Buying Advice 5 acres in national forest
   / 5 acres in national forest #1
Krp41151
I am purchasing a 5 acre track of land in San Jacinto County, Texas. There is a substantial amount of small pine and hard wood thickets that need to be cleared, and all the other duties I need to perform with a small tractor. I am thinking of somewhere around 30-50 hp max. Any suggestions about type and cost I should expect would be appreciated. I suspect I will need a mower/shreder, box blade and auger. Thanks in advance
   / 5 acres in national forest #2
I am thinking of somewhere around 30-50 hp max. I suspect I will need a mower/shreder, box blade and auger. Thanks in advance
get 4WD with a front end loader. With that equipment you should be looking at 30k for a new machine without a backhoe.
As far as the manufacturer..... find a good dealer and get something that is servicable in your location.
You will get more machine, but a smaller selection if you buy used. You may find a backhoe useful for cleaning up after the clearing and other tasks.
Avoid the auctions, check craigslist and your local dealers.
   / 5 acres in national forest #3
I have about the same type land. I have 45HP Ford w/FEL ,BoxBlade, etc. and have found it to be adequate but somewhat marginal, if that makes any sense. I went ahead and hired a dozer to push up 3 acres of thickets then cleaned up with my rig. As far as cost there is a reputable used dealer in my area, I bought mine rebuilt for under 10K.
   / 5 acres in national forest #4
With only 5 acres, I'd go with a 30 hp (pto) tractor with hydrostatic tranny, 4WD, FEL with 5-ft wide bucket, 2 rear hydraulic remotes for mowing, etc once the tree problem is handled. Clearing your trees is a one-time job and is work for much larger equipment--I'd hire the work done by someone with the proper equipment, pay the price, put that chore behind you and enjoy seat time on your new tractor.
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
New/Unused IRMC Massage Chair (A57454)
New/Unused IRMC...
2019 Ford F-350 4x4 9FT Flatbed Truck (A56858)
2019 Ford F-350...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
Toro z turn (A56859)
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
