4x6 gator
/ 4x6 gator #1
acattard
Copper Hill
4x6 gator
Hi, I am putting a snow blade on my 4x6 gator. Do I need to put stiffer shock absorbers on the front?
Tony
/ 4x6 gator #2
It may help. I have them on mine and was going to do the blade but decided against it. Keep in mind they have a very low clearance and only have so much power. Any significant snow fall will cause it to struggle. If you are simply looking for something to push a couple inches here and there you will be fine. I have a 1/4 mile drive and ended up going with a blade on my compact. Good luck and post up some pics!
/ 4x6 gator #3
It would probably be a good idea since as dwost said, they have a very low ground clearance to begin with. Mine has the factory upgraded stronger absorbers, I believe it was part of the snow plow prep package.
Gehl RS6-34 (A64119)
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
SARLO (A64557)
SARLO (A64557)
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
3096 (A63117)
3096 (A63117)
