4x6 gator
   / 4x6 gator #1
acattard
Copper Hill
4x6 gator
Hi, I am putting a snow blade on my 4x6 gator. Do I need to put stiffer shock absorbers on the front?
Tony
   / 4x6 gator #2
It may help. I have them on mine and was going to do the blade but decided against it. Keep in mind they have a very low clearance and only have so much power. Any significant snow fall will cause it to struggle. If you are simply looking for something to push a couple inches here and there you will be fine. I have a 1/4 mile drive and ended up going with a blade on my compact. Good luck and post up some pics!
   / 4x6 gator #3
It would probably be a good idea since as dwost said, they have a very low ground clearance to begin with. Mine has the factory upgraded stronger absorbers, I believe it was part of the snow plow prep package.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
Kubota RTV500 (A47384)
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
