4x6 Bandsaw Cut Speed
   / 4x6 Bandsaw Cut Speed #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
What's an approx. guesstimate for how long it should take to get thru 2" sched. 40? Mine must be over 2 min., 1 min. for 1" square tube.. Time for a blade change? I've had the thing so long I don't remember how fast it was when it was new.
   / 4x6 Bandsaw Cut Speed #2
Depends on tooth pitch, blade speed, feed pressure etc
If you use it regularly and have not changed the blade it may be a good idea!
   / 4x6 Bandsaw Cut Speed #3
How long has that blade been on it?
   / 4x6 Bandsaw Cut Speed #4
I have a little different saw, and I always cut as slow as possible. But if I let my saw go it would cut 2 inch sch 40 pipe in just a few seconds. I generally get 8 to 10 months out of a blade, and I use the saw almost everyday. The blades cost about $50.00 ea.
   / 4x6 Bandsaw Cut Speed #5
I think your big ellis is more then a little different.
My porta band would cut that pipe in maybe 10-20 seconds with a somewhat sharp blade. (gotta put that new lenox blade on..) So I think your blade is well past its life span. The lenox bi-metal blades are very good, might want to get one of those.
   / 4x6 Bandsaw Cut Speed #6
Dull blades dont cut a good kerf and almost always try to go to one side - the one with the sharpest teeth. Duller blades dont cut steel at all. They rub thru it. Very hi speed will give a friction "cut".
larry
   / 4x6 Bandsaw Cut Speed #7
How many teeth per inche on your blade? Coarse or fine?
   / 4x6 Bandsaw Cut Speed #8
Before the Ellis I had a saw a little closer to that size, 7x12 I think. Great little saw, just a pain to cut angles with!
   / 4x6 Bandsaw Cut Speed #9
Its fairly coarse. It came with my old porta-band when I got it on ebay, so I dont know how many tpi. I have a new lenox blade I am going to put on next time I am out there. I am sure mine is dull now, as it will not make a straight cut.
At least 15 years :D It doesn't get used much..
I'm guessing the one on it has about 15 TPI, maybe 20. Cuts real straight, just a little slow. I picked up a new one, was just wondering how fast it 'should' cut.
2005 MGL. ENGINEERING 7436 CONVEYOR (A53426)
2005 MGL...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
2012 Freightliner M2 106 Braun Ambulance (A51692)
2012 Freightliner...
