4x4 not working 2001 tc40da
   / 4x4 not working 2001 tc40da #1
Scratchnbell
Fish Camp,California
New Holland 2001 TC40d
I'm digging a pond.
A few times I got on pretty uneven terrain.
Now my 4X4 will not work. I can turn the front wheels and they spin in opposite directions when the front end is off the ground. When I rotate the drive shaft the front wheels turn. When I have the 4x4 lock in place I do not hear any grinding.
Anyone got any ideas? Or a service manual on CD? this looks like it maybe an expensive fix.
thanks
Bob
after looking at it further, I noticed that the shifter controls a pull cable with a spring in-line. This cable runs to the front "gear" box with a lever on it. This lever is not moving to engage the FWD system. I tried turning the tires and gently tapping that lever to engage the system but it wouldn't budge.
Bob
   / 4x4 not working 2001 tc40da #3
Bob
Bob,
I think that spring-controlled lever is your "sensitrak" FWD that is controlled by the lever on your left side near your transmission range lever (if yours is the same setup as mine). Have you pulled up on the lever that is located in the back left of the driver's compartment (behind the seat)? That should lock in all four. My sensitrak doesn't work consistently either.
Best of luck!
Ok my bad!
There is a second lever that sits behind the seat on the left. This lever has to be pulled up for the FWD to work. I don't know if it is a supersteer thing or not. Mine has TWO levers to make the FWD.
I had never even seen that second lever before today.
Bob
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
