4x10 EHydro Fault Code 11
/ 4x10 EHydro Fault Code 11 #1
mvanhaerents
S.E. Michigan
Deere 4410
I just thought I would post some information if any of you out there get a fault code 11 and the tractor stops moving in either direction. If you unplug any of the following sensors (MFWD, flywheel, forward potentiometer, reverse potentiometer, TPS) and check the voltage from the orange to the black it should be 5.0 volts. All of my sensors were reading 2.5V. Unplug the MFWD and Flywheel sensors each separately and see if the voltage returns back to 5.0 volts. My flywheel sensor had gone bad, and must have been pulling current to ground and lowering all the sensor's voltages. Replacing the sensor fixed the fault code 11 (short,short,long,long) and the tractor moves once again!
John Deere 8320R (A64126)
John Deere 8320R...
Rhino SE415A (A64126)
2008 Chevrolet Silverado Pickup Truck (A62613)
2008 Chevrolet...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
2020 KENWORTH T60 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 KENWORTH T60...
YALE FORKLIFT (A63291)
